- 4 May 2012
I've been weighing up the options of either gunning for a GTX 690, or spending the same amount of money (or thereabouts) for two MSI Twin Frozr III GTX 680s. Now, I am aware of some pros and cons for each, but I was wondering if I could get a few pointers as to which is truly the better option.
GTX 690 Pros:
- Makes less noise
- Cooler than a reference GTX 680
- Consumes less power
- Only takes up one PCI-E slot
- Similar cost
- Looks the business
- Highly exclusive
GTX 690 Cons:
- Slower clock speeds
- Lower average framerate performance based on benchmarks and reviews
- Highly unavailable
Twin Frozr SLI Pros:
- Better framerate averages based on benchmarks and reviews
- Far cooler than reference boards, but I do not have temperature figures for them in SLI vs a GTX 690
- Allows for one card to be shut off when not in use
- Similar cost
- Easy to obtain (could have two by Tuesday if I ordered now)
Twin Frozr SLI Cons:
- Uses more power
- Makes more noise
- Uses up two PCI-E slots
I'm sure there are more pros and cons that I'm not thinking of, but given the options, which would you opt for and why? The SLI/690 configuration is in no means a necessity, but I am using it as a method of prolonging the lifetime of usefulness of the PC by putting in the top-end goodies which should last around twice as long as a single card. I also do a load of HD video editing and rendering, so the overkill is somewhat justified. Somewhat...
Pricewise, I can get the GTX 690 for £799 at the cheapest with a 1-2 month waiting list application, and the Twin Frozr cards for a combined cost of £840 with a two week wait, or £900 if I want them now.
Thoughts?
GTX 690 Pros:
- Makes less noise
- Similar cost
- Highly exclusive
GTX 690 Cons:
- Similar cost
- Uses more power
- Makes more noise
Thoughts?
