First build for £800
24 Apr 2012
It'll be for gaming (BF3, Skyrim and some other demanding games such as roller coaster tycoon 2:p).
I'll need the keyboard, mouse, moniter and OS.
I'm happy to spend a bit over £800 if it is worth it.
Thanks in advance.
By the way do I need speakers?
Depends whether your monitor has speakers (should have a line in if it does) and/or you want speakers I guess
Also I need something to connect to wireless internet
I bout a cheapy (£15-£20) pcie wireless one but kind of regret it, was a pain find somewhere to put the system and get a relatively decent signal, I kind of wish i'd spent some more and tried a homeplug like http://www.overclockers.co.uk/showproduct.php?prodid=NW-032-TP, not sure if they are any better as never used one but might be better.
By the way do I need speakers? Also I need something to connect to wireless internet.
I would also recommend homeplug adaptors if you can use them, avoids wireless!
If you want/need wireless:
http://www.overclockers.co.uk/showproduct.php?prodid=NW-023-TP
or
http://www.overclockers.co.uk/showproduct.php?prodid=NW-054-TP&groupid=46&catid=1597&subcat=1622
you are going to be better going for some decent homeplugs IMO, long as you get some that are 100mbps, the connection you receive shall be better then anything wireless can offer, specially if you're gaming.
