 - 8 Oct 2007
Look on ebay get a canister for £20-25
			So the warm air can blow on you...
I assume you know how convection works (on skin and on an air cooled engine, for example) and how even on a hot day, travelling at even minor speeds will cool you.
I don't think it would cool down a car that's been sitting in the sun all day in a few minutes nor do I want to be blown inside out at 70mph just to get a bit of cool air. It's 2012, not 1962.
	independents re gas form £50So, it's warm enough to test out the aircon!
5 minutes of driving about and the air isn't cold... wonderful.
Stop off at Halfords who want £49.99!!!! for the bottle and gauge.... I think not!
Is there a cheaper way of doing it rather than paying £50 for me to do it, or £50 for someone else to do it?
I took my car last year to an AC specialist, he pressure tested it and found no leaks so he regassed it, got nice cold air out of it. The next day nothing, so took the car back and he found a leak in the condenser. He couldn't explain why the leak wasn't detected so even the experts can come a cropper.
It most likely wasn't detected because it wasn't there. If your system needed re-gassing then it hadn't been running properly (if it was even on) for some time and so after it passed the pressure test it was gassed and appeared to run fine however it broke soon after. Happens a lot with A/C gear, when we recommission fixed A/C units that have been out of service for a while even if they pass all the checks and appear to be working we still send somebody back a few days later to check it as per regs.
He definitely checked the system over with a 'lamp of leaks' and said that he could see some of the dye had leaked out near the bottom right of the condenser. It better be the bloody condenser as I've just gone and order a replacement.![]()
If he saw the the dye under ultra violet light then hopefully that should be the leak, unless he sprayed some dye there to look like it was leaking![]()
Is there any brackets there around there which hold the condenser in place, reason being I did my neighbours car a few years ago (Peugeot 306) and the bracket which holds the pipe down managed to rub through it!![]()
Can anyone recommend someone decent for this in the Midlands? My '99 Focus AC has never worked in the 4 years I've had the car.
The mechanic who services the car said he couldn't even hear the pump working though so could need more than a re-gas?
I dont get the hate towards Kwik fit, they use the same machinery as every other A/C service providers. Your simply at the mercy of whoever operates the machine.
