I am running a 3770K on a Asus P8Z77-V PRO with a Phanteks PH-TC14PE cooler. I ran the Asus AutoTune utility in Windows last night to OC my new CPU for the first time. It went up to 4.6, however, RealTemp GT showed one of the cores reaching 91c (the others were in the mid to high 80s) during the stability test that is part of the AutoTune utility. It reached this temp at load from about 4.5 onwards. This seems very high as peope are reporting stable at 4.6-4.7 with 70c at load.
I know that using a utility like this is not the best way to do it and that it tends to use higher voltages which are not great for the CPU. I will follow the guides on here later in the week and do it properly. Also, I read that different stress testing apps push the CPU to different temps at load. What is the best one to use?
Please advise on my why my temps were high last night.
PS> My cooler is mounted correctly and securely and thermal paste applied in a very small pea size in the centre of the CPU, paste not spread, cooler just appied on top and secured (not lifted off again after being pressed down). I'm using the Phantek paste, however, I also have a tube of MX-4. My case is a white Corsair 600T with all fans working perfectly.
Thanks.
Thanks.
as realtemp would read 80ish on prime and the thermal radar said the CPU was sub 60
