560Ti - 448 Core or 2GB VRAM?
I'm inclined towards the 448 core as I didn't have any VRAM issues with 1.25GB on my GTX570. Then again, what resolution do you run?
It's a pity about the CUDA support because the HD7850 is a better option than both. At stock it's about GTX560Ti speeds but people are getting upto a 50%! overclock on the core, making it a hell of a lot faster.
Although the name implies differently the 560ti-448 is more of a castrated 570 than a beefed up 560ti architecturally speaking, unless you really need the extra ram I would say go with the 448.
To be fair I don't think there's much point buying a 2GB 560Ti generally nowadays unless you've got one and you're going SLI with them.... and then there's better options available.
I would go with the GTX 560Ti 448.
+1, if you were going to SLI then 2GB cards would be the better option (though for the price of 560ti 2GB SLI you could get a 670 which would be a much better choice)
as a single card, the 448 will most likely be the better choice as at options that the 1.2GB becomes an issue, a single 560ti will struggle anway
