To celebrate the Diamond Jubilee (and lets face it, the bit we are mainly interested in, the super long Bank Holiday!) we have put together a range of dazzling deals for you (geddit? Diamond, dazzling...? I'll get my coat...)
For this weekend only, you can make some great savings on carefully selected products and we are also offering FREE DELIVERY ON ALL UK MAINLAND ORDERS UNTIL 4PM TODAY!
Simply use voucher code "ICANTWAIT" when you check out. Minimum order value of £50. Offers run until next Tuesday/whilst stock lasts.
*For full terms and conditions of this promotion please visit the link below.
http://goo.gl/6iphS
Boogie Bug AimB.Pad XL Gaming Mouse Surface @ £10.99 inc VAT
The AimB.Pad has been especially designed for gamers looking for precision, fluidity and the perfect harmony between slide and friction. This XL version also represents an essential tool for graphics designers, architects and other users looking for precision and wide movements. Its surface has been made with flexible textile material that not only assures fluidity and precision in the movements, but also allows the AimB.Pad to be folded, rolled up and transported.
- Dimensions: 450mm x 900mm
Was £16.99 Inc. VAT
Only £10.99 inc VAT.
ORDER NOW
Razer Chimaera 5.1 Wireless PC & Xbox Gaming Headset - WITH FREE DIRT SHOWDOWN @ £141.98 inc VAT
FREE DIRT SHOWDOWN PC GAME *WHILE STOCKS LAST*
The Razer Chimaera 5.1 Wireless Gaming Headset for Xbox 360 gives you a true-to-life surround sound experience. Building on our extensive gaming audio expertise from PC gaming, this wireless headset offers pinpoint tournament grade 5.1 positional audio with extra large circumaural ear cups for maximum comfort.
The base station doubles up as a charging dock and audio processing unit, giving you the option to adjust the game sound and link up to four base stations to talk to your teammates over a lag-free, local communication channel.
5.1 Channel Dolby Surround Sound for Pinpoint Positional Audio
Offering the full range of surround sound, with drivers tuned for 3D positional audio the Razer Chimaera 5.1 Wireless Gaming Headset for Xbox 360 will allow you to anticipate your enemies every step and hear the true game sound in full detail.
5.8 GHz Frequency Headset for Interference-free Wireless Performance
The Razer Chimaera 5.1 allows a true wireless Xbox experience for up to 8 hours with no cables restricting your movement. Using the 5.8 GHz frequency protects this headset against almost all wireless interferences
Dedicated Lag-free Local Team Communications
Up to four Razer Chimaera 5.1 base stations can be connected to create a lag-free, crystal clear voice channel for dedicated team conversations
• Wireless Headset:
• Circumaural Design with 50mm Driver Units
• Volume & Mic Control Buttons on the Headset
• 3 Preset EQ
• Detachable 2.5mm Microphone Cable
• Dimensions: 200mm(W) 204mm(H) 88mm(D)
• Headphones:
• Radio Frequency: 5.8GHz
• Dolby Headphone / Dolby Pro Logic II / Dolby Digital
• Wireless Range: 33ft / 10m
• Frequency Response: 20 - 20,000 Hz
• Impedance: 32O at 1kHz
• Sensitivity (@1kHz, 1V/Pa): 105dB +/- 2dB
• Drivers: 50 mm, with Neodymium Magnets
• Batteries: 2 AAA Batteries (Up to 8 Hours Battery Life)
• Charging Time: 3 Hours
• Warranty: 1 Year Manufacturer Warranty
Cables Included Razer Chimaera 5.1:
- Digital optical cable
- RCA to RCA cable
- 3.5mm to 3.5mm cable
- 2.5mm to 2.5mm cable
- AC power adapter
Was £158.99 Inc. VAT
Only £141.98 inc VAT.
ORDER NOW
NZXT Phantom Enthusiast USB3.0 Full Tower Case - Black @ £94.99 inc VAT
NZXT presents the cutting edge Phantom Full Tower Chassis. Designed with sleek, pristine contours, the Phantom radiates personality and quality. As with all NZXT products, we strive to set apart our customers from the rest with unique, original designs – we run the extra mile so you won’t have to settle with the typical rectangular box. The Phantom delivers high performance cooling advantages with 7 fan cooling options, dual radiator support, quad watercooling cutouts, and five 20W per channel fan controls. An innovative 5.25” screwless system, vast space to encompass 7 hard drives, and five 5.25” bays enable smooth customization. Establish your power, your presence.
- High Performance Cooling Advantages
– Phantom’s extensive cooling capabilities include 7 fan cooling options with dual 200mm, single 230/200mm, triple 120mm, and front 140mm fan options.
- NZXT includes dual radiator support, quad watercooling cutouts, and an integrated fan controller with up to five 20W channels.
- Simple Installation
– Phantom celebrates an array of innovative features designed to enhance every stage of the build
- Meticulous cable management is easily attainable with large spacing behind the motherboard.
- Innovative all-new 5.25” screwless rails make installing and swapping HDDs an effortless process
- Rubber grommets dampens vibration during operation.
- LED on/off button to control fan lighting
- Rubber PSU and case feet to reduce vibration
- Easily removable front and top panels
- Top mounted USB, Audio/Mic, and E-SATA ports
– Features support for larger heat sinks, graphics cards, and E-ATX motherboards enabling enthusiasts to include any of today’s hottest components
- Vast space within the enclosure allows for 7 hard drives with SDD support and up to five 5.25” bays
Was £109.99 Inc. VAT
Only £94.99 inc VAT.
ORDER NOW
Transcend 32GB Class 4 Micro SDHC Card **Perfect for Galaxy S3 Mobile Phone** @ £12.98 inc VAT
nonl2brFeaturing a minimum write speed of 4MB/s. Transcend's Class 4 microSDHC cards are a smart and cost-effective choice for you to capture and store more of your everyday life with your mobile gadgets. Each card contains built-in ECC (Error Correction Code) that automatically detects and corrects errors during data transfer, and also utilizes a sophisticated wear-leveling algorithm for consistent long-life operation.
- Class 4
- Ideal for Mobile Phones, including the new Samsung Galaxy S III
- Fully compatible with SD 2.0 Standards
- SDHC Class 4 compliant
- Easy to use, plug-and-play operation
- Built-in Error Correcting Code (ECC) to detect and correct transfer errors
- Complies with Secure Digital Music Initiative (SDMI) portable device requirements
- Supports Content Protection for Recordable Media (CPRM)
- Allows In System Programming (ISP) for updating firmware
- Supports auto-standby, power-off and sleep modes
- RoHS compliant
Only £12.98 inc VAT.
ORDER NOW
SteelSeries Siberia v2 Gaming Headset - Black & Gold Anniversary Edition (51110) @ £74.99 inc VAT
Based on the award-winning SteelSeries Siberia Full-size Headset, the v2 features major enhancements in sound quality, comfort and its microphone. Every element of the v2 has been optimized for pro gaming, making the headset a preferred piece of equipment for the worlds' best competitive PC gamers - the most demanding headset users in the world.
Sporting 25% larger 50mm driver units, the SteelSeries Siberia Full-size Headset dramatically boosts overall acoustic performance. Experience a rich and detailed soundscape from immersive atmospheric background music to precise 3D positional sounds of footsteps, gunfire and more.
The close type ear cups feature thick leather padded cushions built from sound dampening foam, designed to offer passive noise reduction from loud surroundings and improve comfort over prolonged use. A virtually invisible uni-directional microphone can be retracted from the left ear cup, optimized for essential voice communications.
The v2 remains lightweight and its trademark headband suspension construction makes it extremely comfortable for use over long periods of time.
- LIMITED EDITION COLOURWAY
- Closed type headphones.
- Pull-out microphone.
- Crystal clear high, low and mid-tones.
- 50mm driver units.
- Lightweight suspension construction.
- Integrated volume control located on the cord.
- 2 years warranty
Was £89.99 Inc. VAT
Only £74.99 inc VAT.
ORDER NOW
Razer Onza Tournament Edition Professional Gaming Controller for Xbox 360 & PC @ £39.98 inc VAT
The Razer Onza TE gaming controller for Xbox 360 is designed to give professional gamers the competitive edge by bringing maximum customizability to the Xbox 360 controller. Featuring adjustable resistance on both analog sticks and putting two fully programmable Multi-Function Buttons (MFB) at the fingertips, the Razer Onza TE allows every professional gamer to tweak the controller to their individual preferences.
An improved D-pad, Hyperesponse technology on the backlit action buttons, and PC compatibility make the Razer Onza TE the choice for any competitive gamer. With a 15 foot super long lightweight braided cable and a quick release USB connector, the Razer Onza TE is made for tournament-grade lag free gameplay even during the most crucial moments.
The resistance on both analog sticks of the Razer Onza TE is freely adjustable enabling you to fine-tune the force needed to tilt the analog stick, giving you the right resistance to achieve the optimal precision in any genre. Whether you want a high resistance for a racing game or minimal resistance for precise aiming in an FPS game, the adjustable resistance of each analog stick gives you the edge in every game you play.
Two extra buttons positioned above the trigger buttons on both shoulders of the Razer Onza TE put the commands you deem most important at your fingertips. Whether it’s one of the action buttons (A,B,X,Y), the analog stick button, an additional bumper or trigger button, the Back or Start button, these Multi-Function Buttons (MFB) let you actuate mission-critical commands at the most comfortable location on the Razer Onza TE for maximum adaptability in the heat of battle.
The legendary Razer Hyperesponse technology allows you to actuate buttons faster to fire shots and initiate combos instantaneously, while reassuring you with a crisp tactile feedback. The backlit buttons of the Razer Onza TE are designed with a shorter travel distance and minimized debounce time to increase your actuation speed to stay ahead of the competition.
- 2 Adjustable resistance analog sticks
- 2 Multi-Function Buttons (MFB)
- 4 backlit Hyperesponse action buttons
- Precision D-Pad
- Non-slip rubber surface
- Quick release USB connector
- 15 foot, lightweight, braided fiber cable
- Approx. size in mm: 109(L) x 154(W) x 60.5(H)
Was £49.99 Inc. VAT
Only £39.98 inc VAT.
ORDER NOW
TP-Link 450Mbps Wireless N Dual Band PCI Express Adapter (TL-WDN4800) @ £27.98 inc VAT
What This Product Does
TP-LINK’s 450Mbps Wireless N Dual Band PCI Express Adapter, TL-WDN4800 allows you to connect a desktop computer to a wireless network and access a high-speed wireless network connection. Complying with IEEE 802.11a/b/g/n, the device can use the 2.4GHz or 5GHz channels and provide wireless speeds of up to 450Mbps which is ideal for users seeking a highly robust, bandwidth intensive wireless networking experience, particularly with HD video streaming and online gaming.
Dual Band
Dual Band is the latest wireless technology allowing the adapter to connect with a 2.4GHz or 5GHz network. This allows you to check e-mail and browse the Internet using the 2.4GHz band or stream HD movies and other media on the 5GHz band. The advantage of working on the 5GHz band is that, unlike the crowded 2.4GHz band shared with microwaves, cordless phones and other wireless networks, it has much less interference and can provide a more stable wireless signal, which is ideal for online gaming and HD video streaming.
Wireless N Speed up to 450Mbps
Both the adapter’s 2.4GHz and 5GHz bands support the maximum speed of up to 450Mbps, which generates a maximum theoretical wireless throughput bringing you a limitless wireless experience.
WPA / WPA2 Encryptions - Advanced Security
WPA/WPA2 encryption standards ensure your wireless connection is safe from intruders.
Easy Operation
TL-WDN4800 comes with a CD utility that helps you complete the software installation and wireless network settings, including security configurations and wireless connection, which makes setting up your network so easy that even for novice users should be up and running in minutes.
Was £38.99 Inc. VAT
Only £27.98 inc VAT.
ORDER NOW
Samsung 256GB SSD 830 Notebook/Apple Series SATA 6Gb/s KIT with Norton Ghost - (MZ-7PC256N/EU) @ £153.95 inc VAT
Outstanding Performance in Multi-Tasking
Samsung’s fast random read speeds (up to 80,000 IOPS) maximize performance* when it matters most. A Samsung SSD is the ideal solution for your everyday computing needs, such as web browsing, document creation, viewing or editing multimedia files, playing PC games, etc.
Lightning Fast Speed. At Your Command
The 830 Series’ 520MB/s sequential read speed provides lightning fast access to your files, loading large multimedia files quickly and smoothly.
Sustained Performance and Unrivaled Reliability
Samsung SSDs are designed and build completely in-house. The Samsung SSD 830 Series is optimized for exceptional, sustained performance and unrivaled reliability through its specially- engineered wear-leveling and garbage collection algorithms.
A Complete, User-Friendly Solution
The Samsung SSD 830 series is available with a user-friendly installation kit, including a full version of Norton Ghost, an interactive installation guide, and premium installation tools for both desktops and laptops.
Toggle DDR NAND Flash
Use the wider image option when adding this feature. We would like to capture all of the data represented on this specific feature image. However, do not use this feature image in this document, use the actual image in images folder. Samsung’s 20-nanometer-class toggle DDR NAND Flash chips enable data transfer rates of up to 133 megabits per second (Mbps)-more than three times faster than conventional (40 Mbps) single-date-rate (SDR) NAND Flash chips.
3-core ARM9-based MCX Controller
While most SSD makers rely on generic, dual-core controllers, Samsung has developed its own proprietary, triple-core MCX controllers that excel in multi-tasking and help to assure stead performance over time. Based on an ARM9 controller, its three CPU cores can execute multiple instructions such reading data, writing data and optimization.
256MB DDR2 DRAM Cache Memory
256MB of DRAM cache memory helps maintain stable random read performance, even if the access range is increased.
The Samsung SSD 830 Series boasts superior random read speeds (up to 80,000 IOPS) and faster
sequential read and write speeds (up to 520 MB/s & 400 MB/s respectively). It’s the ideal solution for
Samsung’s SSD Magician software eliminates the confusion and uncertainties of SSD management,
making it simple for users to maximize the performance and lifetime of their Samsung SSD. The
software helps to maintain the SSD at its peak condition, giving you the same great performance and
reliability throughout the life of your PC. In addition to its performance maintenance features, SSD
Magician also provides system information and facilitates performance benchmarking, performance
optimization, OS optimization, firmware updates, secure erasing, and over provisioning.
- Capcity: 256GB
- Dimensions (LWH): 100 x 69.5 x 7 (mm)
- Samsung Toggle NAND
- Sequential Read: 520MB/s
- Sequential Write: 400MB/s
- 4K Random Read: 80,000 IOPS
- 4K Random Write: 36,000 IOPS
- Warranty: 3 years
- Norton Ghost
- SSD 2.5"-3.5" tray
SPECIAL LOW PRE-ORDER PRICE Only £153.95 inc VAT.
ORDER NOW
Cooler Master Silent Pro Modular 700W '80 Plus Bronze' Power Supply @ £64.99 inc VAT
The Silent Pro series is a new range of single rail power supplies from Cooler Master that's addressing a growing market demand for powerful single rail 12V PSUs. With up to 50A on the 12V rail, the SilentPro series deliveries where it count and won't have any problems powering even the most demanding SLI or CrossFire system,.
The SilentPro series is also the first power supply from Cooler Master to feature flat modular cables for improved airflow and cable management. It also comes with anti-vibration silicon pads to remove possible vibrations from the PSU.
- High Quality Japanese made capacitors
- 85% efficiency
- Copper and Aluminum heat pipes for high efficiency cooling
- Silicon shock absorption rubber pads around the edges of the power supply
- Modularized flat cable design to eliminate clutter and improve airflow inside the chassis
- Two 6+2 PCI-E connectors to support various graphic card setups
Was £89.99 Inc. VAT
Only £64.99 inc VAT.
ORDER NOW
Krypton Z68 TURBO Intel Core i5 2500K 3.30GHz @ 4.00GHz Overclocked Bundle @ £309.98 inc VAT
Designed by experts the "Krypton Z68 TURBO Bundle" is a pre-configured high performance "plug and play" bundle featuring optimised settings. The Guaranteed 4.00GHz overclock has the processing power and speed unseen at this price point ever before. The "Krypton Z68 TURBO" will accelerate your computer experience into the next level.
Why You Should Buy This Bundle?
- A solid, optimised 4.00GHz overclock profile provides outstanding processing performance
- Prebuilt, overclocked and configured. Just "plug and play"
- 8 Hours stressed tested and quality controlled
- 4GB of Dual Channel DDR3 memory delivers unsurpassed bandwidth
- USB3, SATA 6GB/s and Intel Ethernet for next gen computing
Bundle Specification
- CPU: Intel Core i5 2500K 3.30GHz @ 4.00GHz Sandybridge CPU
- Motherboard: Gigabyte Z68AP-D3 Intel Z68
- RAM: Kingston HyperX Blu 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel
- Cooler: Corsair A50 CPU Cooler
Service Package
- Full 12 Month collect and return warranty
- Each specification is assembled from handpicked components for compatibility and stability
- Telephone, web note and forum technical support
Note - Please note that adding in additional memory to the spare slots will require new BIOS settings and the maximum clock speed attainable may be significantly reduced. OcUK recommend a quality brand PSU for use with all our bundles such as the Corsair TX & HX range. Updating the BIOS on the overclocked bundle range will void the warranty on the overclock. If you update the BIOS we will no longer be able to provide support for configuring and maintaining the CPU overclock.
*Please allow between 24 and 48 hours for your system to be built and configured. This may take longer during busier periods.
Was £329.98 Inc. VAT
Only £309.98 inc VAT.
ORDER NOW
"Titan 8700i Pulse" Intel Core i5 3570K 3.40GHz @ 4.40GHz DDR3 Ivybridge System @ £526.00 inc VAT
Get ready to game with the "Titan 8700i Pulse"! Featuring the Intel Core i5 3570K overclocked to a ridiculous 4.40Ghz, you can enjoy ultra smooth framerates and an immersive computing experience. With a the latest DX11 graphics cards, equip yourself ready for the game ahead. With a massive 500GB hard drive you will never run out of space for your essential data. 8GB of memory provides a smooth computing experience, the "Titan 8700i Pulse" is finished off with the fantastic range of gaming cases to choose from.
Why You Should Buy This System
- A guaranteed 4.40GHz performance for the price of 3.40GHz
- Cinematic DX11 graphics
- Precision built and cabled by Overclockers UK expert technicians
- USB3, SATA 6GB/s, Intel Ethernet for next gen computing
- All systems with an operating system selected ship out with a pre-installed 180 day trial of Panda Antivirus 2012
System Specification
- Case: NZXT Source 210 Elite Case - White (default choice, options avalable)
- Power Supply: OCZ ZS 650w PSU
- CPU: Intel Core i5 3570K 3.40GHz @ 4.40GHz Ivybridge CPU
- Motherboard: Gigabyte Z77-D3H Intel Z77 (Socket 1155) DDR3 Motherboard
- Cooler: Prolimatech Super Mega CPU Cooler
- RAM: Samsung Green 8GB DDR3 1600MHz Dual Channel Kit
- Hard Drive: 500GB HDD
- Graphics Card: ATI Radeon HD 5450 SILENT 512MB (default choice, options available)
- Sound: Realtek 7.1 Channel Sound (On-Board)
- Optical Drive: LG DVD+/-RW SATA Drive
Service Package
Is this System for You?
Immense overclocks, powerful graphics and sleek hardware all combine to create the "Titan 8700i Pulse", perfect for the gaming enthusiast.
Note - If you would like to make a small change to the specification call our sales team on 0871 200 5052 and they will be happy to help.
* No OS systems are fully tested with the same extensive methods as systems chosen with an operating system. Including tests such as CPU, memory and GFX stress tests. All no OS systems are formatted completely before shipping.
*Please allow between 24 and 48 hours for your system to be built and configured. This may take longer during busier periods. S
Was £697.96 Inc. VAT
Only £526.00 inc VAT.
ORDER NOW
dammit lol
