Hey guys. I'm sure you can work out what the question is from the title
I've currently got the standard 120mm Corsair fans (CFM 45, 25 DBa) the H80 came with installed and want to replace them with either a) 2 x 1850 rpm Gentle Typhoons (58 CFM, 28 DBa, £19.99), b) 2 x CM Sickleflow (69.69 CFM, 19 DBa, £6.98) or c) another fan you'd HIGHLY recommend.
From what I've read the CMSFs are 1/3 the price of the Scythes, over 15% higher CFM and considerably quieter (and comes with a funky LED). Is there something I am really missing big time here or is the choice as obvious as it looks? The numbers do seem to speak for themselves, and frankly anything would be better than the Corsairs that the H80 came with.
Any and all help is appreciated
I find that hard to believe (1.6 sounds fair, 7.7 a bit off).
