- 8 May 2011
- London
As in the title, I need to induce a bsod quickly and without damaging my system for a little project I'm working on. Best way to do it?
http://pcsupport.about.com/od/tipstricks/ht/makebsodxp.htm
Then you can simply undo this when you're done![]()
Im interested, how will this help you with your project?
download a cpu over clocking program, raise the clock speeds very high
easy
job done![]()
Yeah because that's totally safe.
Go into Device Manager (Start > Right click "Computer" > Manage > Device Manager). Update the driver for one of your components, manually select a driver, select the wrong one (for example, tell the PC your sound chip requires a graphics driver) and it should blue screen nicely and safely.
During Windows boot pressing F8 and selecting "Last known good profile" should get you back up and running, but I can't promise. Try it and let us know if this works, or if you had to do a fresh Windows install to fix!![]()
i dont think that would work surely if you install the wrong drivers the device just doesnt work
