MOAR MOAR MOAR!!!!!
Epic looking build dude can't wait to see the finished results.
This!
MOAR MOAR MOAR!!!!!
Very nice looking build, I love the clean lines of the case.
On a completely random note, your username - I've been reading it in my head as "five you bee", just realised it should be read as "sub".![]()
would've gone for all of that apart from the ddc, mine is the loudest thing in my pc
clee I think that's an xspc rs240
Looks good
Is that a kink between CPU and res though?
Did you replace the bit of tubing?
I found that if a kinks been there for some time, even after being carefully unkinked ifit is bent even slightly it will kink again![]()
Cut it shorter as it was a bit longer for the angle and just forced it to kink. Should be fine now, will keep my eye on it though.![]()
