- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
Now you have the tools available exclusively at OcUK to build the worlds smallest LGA1155 fully fledged PC.
With the new Lian Li PC-Q05 cases and a specially designed LP motherboard and CPU cooler from Intel.
Brands you really can trust in!
Lian Li PC-Q05A Intel DH-61AG HTPC Case - Silver @ £53.99 inc VAT
The PC-Q05 is designed for the Intel DH61AG ultra thin Mini-ITX motherboard and the Intel HTS 1155LP heat sink. The chassis features intake vent input cooling air to cool the system down. This tiny case can house up to two 2.5" HDDs for extreme data storage.
- Case Type: Mini Tower Chassis
- Dimensions: (W) 284mm x (H) 47mm x (D) 307mm
- Front bezel Material: Aluminum
- Side Panel: Aluminum
- Body Material: Aluminum
- 5.25" drive bay (External): None
- 3.5" drive bay (External): None
- HDD bay: 2.5-Inch HDD x2
- Motherboard Support: Thin Mini-ITX (intel® DH-61AG)
- Maximum Compatibility: Cooler: support the Intel HTS® 1155LP
- Package Dimensions: (W)346 mm x 98(H) mm x 343(D) mm
- Gross Weight: 1.5 KG
- Power Supply: AC 150W adapter (not include)
Only £53.99 inc VAT.
PRE-ORDER NOW
Lian Li PC-Q05B Intel DH-61AG HTPC Case - Black @ £53.99 inc VAT
PRE-ORDER NOW
Intel DH61AG Intel H61 (Socket 1155) DDR3 Mini ITX Motherboard @ £99.98 inc VAT
The Intel® Desktop Board DH61AG powered by the 2nd generation Intel® Core™ processors in the LGA1155 package offers Intel® HD Graphics with best-in-class media processing features in an innovative low z-height, thin Mini-ITX form factor. Fully compatible with low height components such as SO-DIMMs and full- and half-length PCI Express* mini-cards, the DH61AG also supports premium features such as SuperSpeed USB 3, eSATA, and Hi Current/fast charging USB 2.0 ports. Full display output support with HDMI* and DVI-I is complemented by flexible eDP or LVDS flat panel display support. Combination of low height components, premium features, and an external power supply make the DH61AG the perfect solution for high performance AIO systems, tiny FF systems, and home theater PC systems.
Features
Audio Channels 7.1
Product Type Desktop Motherboard
Manufacturer Part Number BLKDH61AG
Manufacturer Website Address www.intel.com
Manufacturer Intel Corporation
Product Model DH61AG
Product Name DH61AG Desktop Motherboard
Brand Name Intel
Number of Total Expansion Slots 3
PCI Express Standard PCI Express 2.0
Total Number of PCI Express Slots 3
Maximum Memory 16 GB
Memory Technology DDR3 SDRAM
Number of Memory Slots 2
Memory Form Factor SoDIMM
Package Contents
1 x DH61AG Desktop Motherboard
1 x Back Panel DC Jack Cover
2 x Cable, Serial ATA, Latching, L-Shaped
1 x Cable, SATA to Power & data for Slimline Drives (Y-cable)
1x DVD, Express Installer
1 x Configuration Label
1 x I/O Shield - Full Height
1 x I/O Shield - Half Height
1 x Quick Reference Guide
Software CD
Green Compliance Certificate/Authority Energy Star
China RoHS
Green Compliant Yes
Gigabit Ethernet Yes
Form Factor Mini ITX
Width 6.7"
Processor Supported
Core i5
Core i3
Core i7
Pentium Dual-core
Celeron Dual-Core
Xeon
Depth 6.7"
Number of SATA Interfaces 3
Total Processor Supported 1
Processor Socket Socket H2 LGA-1155
Processor Technology Turbo Boost Technology
Hyper-Threading Technology
64-bit Processing Yes
Chipset Manufacturer Intel
Chipset Model H61 Express
Onboard Video No
Controller Type Serial ATA/300
RAID Supported No
eSATA Yes
HDMI Yes
DVI Yes
Number of Network (RJ-45) Ports 1
Network (RJ-45) Yes
Total Number of USB Ports 4
Number of USB 3.0 Ports 2
Number of eSATA Ports 1
Total Number of Onboard USB Ports 8
Number of Onboard USB 2.0 Ports 8
Only £99.98 inc VAT.
ORDER NOW
Intel Thermal Solution HTS1155 LP CPU Cooler (Socket 1155) @ £19.99 inc VAT
As desktop form factors evolve with an emphasis on thinness (like All-in-Ones and SFF PCs), cooling solutions needed to evolve to support local integration. The Thin Mini-ITX platform is designed for such applications, and Intel’s HTS1155LP is a core building block that delivers exceptional performance and enables the evolution of the desktop.
- Radiator Dimensions: 77 x 77 x 26 mm
- Heat SinkWeight: 264 grams
- Blower Dimensions: 80x 80 x 22 mm
- Blower Weight: 54 grams
- Blower Cable Length: 20.5 inches or 521 mm
- FanSpeed: 1180 –3380 RPM
- Thermal Interface Material (TIM): TC-1996
Only £19.99 inc VAT.
ORDER NOW
PRE-ORDER NOW
PRE-ORDER NOW
Features
Audio Channels 7.1
Brand Name Intel
Package Contents
Software CD
China RoHS
Green Compliant Yes
Width 6.7"
Processor Supported
Core i5
Core i3
Core i7
Pentium Dual-core
Celeron Dual-Core
Xeon
Depth 6.7"
Onboard Video No
RAID Supported No
eSATA Yes
HDMI Yes
DVI Yes
Network (RJ-45) Yes
ORDER NOW
ORDER NOW
