- 18 May 2010
- London
If I put a new build together can I reuse my Win 7 license?
Yes you can, you can use it so many times even though people say you cant you can.
I have used my OEM copy 3 times already now and its activated on the internet no problem.
If you do have a problem though just ring them and they will give you a 100 digit code
to activate Windows
Will it work? ............. yes
Will microsoft find out and kick your door down? ............ no
Is it being naughty? ............... yes
Do you care? ............. probably not
Does almost everyone do it? .............. yes
At the end of the day it will work, maybe you will have to activate over the phone using the automated system. It is technically naughty as the OEM is for one time use on the first machine but i doubt anything will come of it. Apart from being told off by some on here it wont send you to prison or have your door booted in so go for it.
In my mind if you paid once for it then i dont see an issue in using it for the rest of your life as long as its only on one machine.
But it is a little bit silly isnt it. I cant upgrade my computer and use the license I have paid for?
