Whare is everyone getting 3/8" from. The original post states 1/4". Even Thermochill uses 1/4" on the TA series now.
Check the original post edit time, it was saying 3/8"
'suck with' ? I prefer 3/8 and would be happy if everyone used them. Its all about ID and flowGood on you for manufacturing them in the UK!! You are an onspirarion of what all Niche businesses should be doing!
On another note, are they G1/4 or are we stuck with 3/8?
'suck with' ? I prefer 3/8 and would be happy if everyone used them. Its all about ID and flow![]()
We did originaly do the larger ports on the first test rads we sent out how every one wanted us to do them normally so we compromised.
The difference is negligible.
Using standard g1/4 is better so the user can decide what they want to use, IMO, 1/2 with 7/16 tubing looks best, I don't want to be forced to use 3/8 and I don't really fancy buyin converters.
its the threaded end, not the barb/compression end :\ a la G1/4
you go with barbs and no clamp?
Anyway, I prefer 3/8, probably from the old days when there were no ready made blocks or specifically designed pumps and flow was king!
Yep, clamps ruin the looks, as do compressions :/
Whatttt compressions ruin the looks? I quite like the look of black compressions... probably cause of the way Im going to have my loop.
