I use Keepass on the desktop & KyPass on iOS. I use Dropbox to sync the database.
I use this as well with Windows/android. Fantastic.
I used to reuse a lot of my passwords which is not a good idea.
Lastpass, I use it myself and highly recommend it. Normally I don't trust things like password managers, but Steve Gibson (who coined the term spyware, and does weekly security podcasts, although some think he is a little crazy) did an in depth review on the technical aspects and said Lastpass is pretty much as safe as you can get with a password manager.
It allows easy generation of decent passwords, and easy management of unique password for each website you use.
Free to use for PC browsers, and for a small fee ($12 a year) you get the premium account, which include things like Yubikey support, and a mobile app.
Confirmed earlier that my password is in the dump. Just a minor inconvenience but still frustrating.
Would you mind trusting me where you found it? I've already changed password as a precaution but I'm interested to know if it is in there nonetheless
Mine isnt and it's a strong password, unless the SHA-1 has been salted.
The list that was released was not salted
Potential stupid question, but my password for linkedin is the same as a few of my other passwords. Should I change them all?
Guys, can I ask a small question on Last Pass?
I downloaded the app, and I installed it in chrome. Now, what I am thinking of doing is go on each website I ever logged in (the ones LastPass remembers) and swap the password with one auto generated (and secure) by LastPass.
if I understand correctly, if I update the LastPass entry, it will save my login information for ever (with the new password secured behind a LastPass account).
Am I right?
Also, am i right in thinking they will be stored if I format my PC (as they are stored in the account). So if I log in on a new PC, I will find my saved passwords.
If you say yes to both, then I have found the perfect tool!
BACKUP AND RESTORE
Never lose another password - ever!
An encrypted backup copy of your data is stored in your account at LastPass.com. Securely and seamlessly restore your passwords if you change computers.
Yes that's what i'm doing for the passwords. Simply changing every password to an auto generated 20 character one and saving them all.
As for formatting i'd say so:
Yeah i've been using 3 passwords (all extremely similar) for ever. Never had a problem but about time i got with the times really
One little thing to remember when using lastpass which is sometimes overlooked, it can autologin or autofill the boxes, meaning you should never use the 'remember me' or 'keep me logged in' on websites, that way your browser will never store your login credentials.
Some little things to also watch out for is that the autologin plays up on some sites, for example if you set it to autologin to twitter, when you go to the twitter settings page there is an email address box, and a password box, so lastpass will think 'oh, you are not logged on, let me fill that in and submit it for you'. So in them sort of circumstances you should set it up to never autologin to twitter.com/settings/account
Once you get to grips with it, and go over the features it is great, and I love the yubikey integration which I've set up to be required on everything but my home PC. So if someone does get my master password they still need my yubikey if they are trying to login from anything but my home PC![]()
