Did you look at my frame returns? Seriously, this discussion is a joke when Max Payne 3 does not even push the GPU at all. On full settings, the frames are between 130 and 300.
Let us at least argue about a game that will push the GPU. Maybe BF4 will show the weaknesses of the current GPU. The truth of the matter is the top 4 GPU's can play all current games at fantastic returns.
When frames are as low as 45 in a game, this is when the weaknesses of the top 4 cards will start to show.
Your performance is very different to mine. When I used everything maxed out on my 670 with mild OC (1200Mhz core +500Mhz memory) my frames were suffering around 30-40fps most of the time. I turned MSAA off and got 60fps constant
I maintained 60fps with everything maxed out with MSAA + FXAA with a GTX 690.
So from struggling to get 60fps on my rig to 130-300 on yours that's a huge difference and I'm sure my 670 isn't that far off a 680.
Have you tried using fraps instead of EVGA Precision to show the fps cause I'm using fraps and I've heard some other monitoring programs like afterburner were giving mega bloated fps figures.
