£2500 Budget....
I'm gonna keep posting this until someone buys it *Even though its my dream build*
YOUR BASKET
1 x EVGA GeForce GTX 680 2048MB GDDR5 PCI-Express Graphics Card (02G-P4-2680-KR) £439.99
1 x Intel Core i7-3770K 3.50GHz (Ivybridge) Socket LGA1155 Processor (77W) - Retail £274.99
1 x Corsair Obsidian 800D (6GB/s) Full Tower Case - Black £229.99
1 x Asrock Z77 FATAL1TY Professional Intel Z77 (Socket 1155) DDR3 Motherboard £199.99
1 x Microsoft Windows 7 Professional - Retail (FQC-00133) £169.99
1 x Corsair Dominator 16GB (4x4GB) PC3-14900C9 1866MHz Dual/Quad Channel Kit (CMP16GX3M4X1866C9) **SPECIAL** £139.99
1 x Corsair Enthusiast Series TX850M High Performance 850W '80 Plus Bronze' Modular Power Supply (CP-9020004-UK) £113.99
1 x Western Digital Caviar Black 1TB SATA 6Gb/s 64MB Cache - OEM (WD1002FAEX) £101.99
1 x Crucial RealSSD M4 128GB 2.5" SATA 6Gb/s Solid State Hard Drive (CT128M4SSD2) £99.95
1 x EK-FC680 GTX Full Cover Waterblock - Nickel Plexi £79.99
1 x EK CoolStream RAD XTX (360) £74.99
1 x EK Supreme HF CPU Waterblock - Nickel Plexi £56.99
1 x EK-CoolStream RAD XTX (120) £39.98
1 x EK DCP 4.0 Pump (12v) £39.98
1 x EK Multioption Reservoir X2 250 Advanced £38.99
1 x EK-RAM Dominator X4 - EN (Nickel) £32.99
1 x Akasa FC. SIX Channel Fan Controller - Brushed aluminium - AK-FC-08BK £27.98
1 x EK-FC680 GTX Backplate - Black £19.99
1 x Arctic Cooling MX-4 Thermal Compound (20g) £19.99
2 x Mayhems Pastel - Light Red Coolant 1L £14.99 (29.98)
8 x Scythe Gentle Typhoon 120mm 1150 RPM - 3 Pin £12.98 (103.84)
1 x OcUK Tube Cutter Aluminum 3-14mm £8.5
2 x XSPC HighFlex Hose 3/8" ID, 5/8" OD, 16/10mm, 2m, Clear/UV £6.49 (12.98)
16 x EK PSC Compression Fitting 7/16 [16/12mm] - G1/4 - Nickel £3.29 (52.64)
Total : £2,430.91 (includes shipping : £16.85).
I've never built a system before so originally wanted it built for me.
Long story short I want max settings at 1920x1080 no peripherals needed I've bought all them already from overclockers, no sound card needed either.
Last thread got deleted, apologies to anyone I offended by the offer. It was only meant as a thank you for the help so far.
Anyway Suggestions welcome also any thoughts on this?
http://www.overclockers.co.uk/showproduct.php?prodid=FS-216-OE&groupid=43&catid=2040&subcat=
£820 cpu is overkill imho, & only comes with a 5450 gfx.
http://www.anandtech.com/show/5091/...-bridge-e-review-keeping-the-high-end-alive/9
This has 680 gfx for similar price. And id phone & ask for a
OCZ Vertex 4 256GB to be installed.
http://www.overclockers.co.uk/showproduct.php?prodid=FS-244-OE&groupid=43&catid=2040&subcat=1270
Lemin may I please ask why you would choose the vertex 4 over the 3? they seem to have the same read speed but the 3 has a faster write speed.
Feeling lazy. Can't remember what I said last time so:
YOUR BASKET
1 x OcUK Tech Lab - "Ultima 9600i Kraken" Intel 4.60GHz Quad Core Ivybridge System £1710.00
- 1 x Mayhems Ultra Pure H20 Watercooling Fluid 1L £4.99
- 1 x FREE PANDA 180 Day Trial Anti Virus £0.00
- 1 x No Hard Drive Upgrade £0.00
- 1 x Microsoft Windows 7 Home Premium SP1 64-Bit - OEM (GFC-02050) £79.98
- 1 x System 12 Months Standard Warranty £0.00
Total : £1,813.57 (includes shipping : £15.50).
Apart from gaming, what else will this system be used for?
As Lemin rightly pointed out, there is no need to spend £2500, unless you want to use 3 monitors.
To be honest that Kraken thing I just posted seems to be pretty darn decent even for that money. With £2500 you even have room for peripherals and such.
YOUR BASKET
1 x Palit GeForce GTX 670 Jetstream 2048MB GDDR5 PCI-Express Graphics Card £349.99
1 x Intel Core i5-3570K 3.40GHz (Ivybridge) Socket LGA1155 Processor (77W) - Retail £189.95
1 x Gigabyte Z77X-UD5H Intel Z77 (Socket 1155) DDR3 Motherboard £173.99
1 x Sandisk Extreme SSD 240GB 2.5" SATA 6Gb/s Solid State Hard Drive - (SDSSDX-240G-G25) £161.99
1 x Fractal Design Define XL USB3.0 Full Tower Case - Black Pearl £114.98
1 x XFX 850W XXX Edition Modular '80 Plus Silver' Power Supply £99.98
1 x Seagate Barracuda 7200RPM 1TB SATA 6Gb/s 64MB Cache - OEM (ST1000DM003) £74.99
1 x Alpenföhn K2 Mount Doom CPU Cooler (Socket LGA1156/1155/1366/AM2/AM2+/AM3/AM3+/FM1) £64.99
1 x Corsair Vengeance Blue Low Profile 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CML8GX3M2A1600C9B) £44.99
1 x Asus 24x DVD±RW DRW-24B3ST SATA ReWriter - Black (Retail) £20.99
Total : £1,394.52 (includes shipping : £14.75).
The i5-3750k is more than enough for gaming.
Mobo has a very good onboard sound system, good OC`er and will handle sli if you wish to dual card.
Psu is overkill for a single card, but is sli capable and modular.
Case is subject to your preference.
Cooler comes very highly recommended.
Good Ssd for your OS and games.
Included a 1TB Hdd for storage, you can use your external drive for backup.
Gpu is fairly good, although you can change it for one of your choice.
Also included an OS, unless you already have one, in which case disregard.
In all honesty if I had to buy the parts how difficult is it to put together or would you not suggest it?
I was looking at there system configurator which seems to be good but I would want to change a couple of things they don't offer on the configurator. would they be willing to do that?
i have to say that putting the computer together is simple if your that way inclined, i built my first about a month ago, it was great fun. if your not comfortable doing it yourself then id suggest getting overclockers to build one for you and for £2500 worth of kit i dont think you need to worry about being able to play any current game at 1920x1080. my build cost me £1k and i can play the games i want at max graphics at 1920x1080
Fairly easy and i would highly recommend it. For the satisfaction, alone.
^This
The feeling you get when the first pc you build turns on is just something else :p
Take a look at the system build guide at the top of general hardware its pretty great :D
