Don't you just love it
I'm running water, kill coil and algae. Should probably clean out the algae, but it doesn't seem to be doing much harm. Not as much as the dye in the OP did anyway.
just means its worth having a good spring clean now and then to keep it all checked out and ship shape i guess thats part of the fun
One on my D-Tek Fuzion blocks looked like that a while back and I had been using Feser One fluid. I was quite surprised how much gunk had accumulated in the block and also how discoloured the tubes were from the fluid. Flushed the loop, disassembled, cleaned the block out and just filled the loop back up with distilled water. Had no issues since and that was a good 6-8 months ago.
Hey, just checked my old invoices for this build, guess what the tubing was:
Code:
Products ordered:
   	SKU:	 	AQU-59089
   	Product:	 	Primochill PrimoFlex Pro LRT 3/8" ID - 5/8" OD (10-16mm) Tubing : Black
   	Quantity:	 	3
   	Item price:	 	£ 3.13
________________________________________
   	SKU:	 	AQU-59014
   	Product:	 	Tygon R3400 3/8" ID - 5/8" OD (10-16mm) Tubing : Black
   	Quantity:	 	1
   	Item price:	 	£ 6.80
