I have RIVE and Sabertooth among many ASUS boards. Both are great performers. What are you looking for out of the system??? What are your other components and cooling options???
Hey guys, thanks for the replies. Well, to give you a bit of background here's a wall of text
I'd like to build a very powerful but also very quiet system within an Antec 902 case. Realistically I probably won't use this new system to its full potential straight away, but may do so in the future.
I'd like a motherboard that's reliable, stable, really helps me get the most out of the 3930 K and allows me to overclock this chip as far as safely possible.
I've been reading about various issues that some motherboards have and have even seen some people post that their recently bought 3930 K's do not seem to be as good as the older batches. So I thought I ask around here to see what other people have to say
I haven't decided on my other components yet, again I was hoping to hear what other people have to say. As I've previously mentioned, I want the system to be really quiet, but I also want to be able to keep the CPU as reasonably cool as possible when under load.
I've never fitted water cooling to a PC before and wasn't sure if there'd be much difference between a high end air or water cooler. It feels like I'd be asking for trouble to have water flowing around inside my PC!
Anyway, please feel free to recommend me CPU cooling options (water or air) even though we're in the motherboard section!
One of the things that I'd really like to know is what impact my cooling choice will have on my ability to fit other components onto my motherboard.
Depending on the motherboard I end up choosing, I want to avoid the scenario where my CPU cooling option blocks access to e.g. RAM or PCI -E slots. I'd like to be able to use all available slots, although if I was forced to make a sacrifice I would probably choose to lose access to a PCI-E slot than RAM slots.
Looks like the motherboard I choose will also determine the type of RAM I need, therefore I haven't decided on this yet either, although please feel free to offer suggestions in this area as well
With regards to power supply, I'm looking at the Corsair Professional Series AX1200, what do you think?
Also, I have an msi nVidia lighting GTX 580 with 1535 MB memory and I'm probably going to buy another one for SLi. However I cant find the same card in the ovcerclockers shop anymore, so I may go for the new 6 series cards.
I have an optical drive already, so I'll use that in this new build.
I am however planning on buying a large capacity solid state drive, probably the Crucial RealSSD M4 512GB 2.5" SATA 6Gb/s although it's currently sold out. Good choice?
Lastly, I currently have windows vista 64 bit and I'll probably buy a copy of windows 7 ultimate. I thought about waiting for windows 8, but it looks like it's designed more for tablets and smart phones than desktop PCs.
Also, there's a significant difference in price between the Asus Rampage IV Extreme and Rampage IV Formula, is this reflected in a clear difference in performance between the 2?
Thanks again for the input guys, looking forward to hearing some more advice
