recommend me a good gaming case
18 May 2012
Im looking for a good gaming case that both looks good and has brilliant airflow.
Budget is not particually a problem but dont go too crazy.
If it helps here are some specs I might include:
INtel i7 3770k ( overclocked)
Nvidia GTX 680
Asus P8Z77-V PRO Intel Z77 (Socket 1155) DDR3 Motherboard
Crucial Ballistix Elite 8GB (2x4GB) DDR3 1866MHz
Seagate Barracuda 7200RPM 1TB SATA 6Gb/s 64MB Cache
Creative Sound Blaster Recon3D Fatal1ty Professional Soundcard
OcUK 22x DVD±RW SATA ReWriter
http://www.overclockers.co.uk/showproduct.php?prodid=CA-055-CS
A personal favourite with good airflow, bare in mind that airflow will also be determined by your cable management, which this case allows for, same goes for the Corsair case recommended by cereal3.
Arent the 600T renowned for fan controller fails? Ive read so many threads about them going pete tong.
I got a carbide 500R and its great, not crazy money but simple and has everything you could need, minus fan controller.
http://www.overclockers.co.uk/showproduct.php?prodid=CA-060-CS&groupid=701&catid=7&subcat=1489
Hmm, can't say I have heard of the fan controls failing, mine has been fine for the past year. The Carbide series are definitely a good choice of case, no matter which one you choose. Corsair cases generally ooze with quality, although, after a little research it sounds like Corsair sent out replacements if the fan controller does fail on the 600T, still if you'd prefer to avoid any contact with customer services, even though Corsair has a top notch service, the Carbide would be a good choice.
600t is a lovely case and i was going to get it, but the fan controller thing worried me, and the be honest, i dont need a controller. Any carbide case would be great, Corsair cases are pure quality. 500R being my fave, only because its all i have ever had of theirs.
