Any cheap 750w PSU's OK?
20 May 2012
Cornwall
I've just re-built my main rig and used all the old bits in my secondary PC. I didn't buy a new PSU so my No2 system is badly under powered (350w PSU)
Here's the spec of the secondary PC:
i7 920
P6T-SE
12gb
2 x Hard Drive
ATI HD 4890
Lots of fans (Antec 1200)
(Haven't overclocked anything yet due to PSU, dont think the stress test would last very long :rolleyes: )
So I'm wondering how good a cheap 750w PSU can be?
If I can get a cheap one that will do the job OK then great.
If the cheap ones are just cheap and nasty then I will probably buy a descent new one for my main PC then use the old one (Hiper Type M 880, about 4 years old) in the secondary system.
If I have to buy one for my new PC would a Corsair AX 750 be a good choice?
New PC spec:
i7 3820
Asus X79 Sabertooth
32gb
2 x Hard Drive
1 x SSD
GTX 670
Water cooled
Thanks in advance ;)
Dont waste money on cheap psu's, a false economy.
OCZ ZS Series 550W '80 Plus Bronze' Power Supply [OCZ-ZS550W-UK]
£49.99 inc VAT
http://www.overclockers.co.uk/showproduct.php?prodid=CA-055-OC&groupid=701&catid=123&subcat=
is the cheapest id get.
Or even better...
Cooler Master Silent Pro Modular 700W '80 Plus Bronze' Power Supply [RS700-AMBAD3-UK]
£64.99 inc VAT
http://www.overclockers.co.uk/showproduct.php?prodid=CA-165-CM&groupid=701&catid=123&subcat=
+1 The OCZ will power the system no problem even with overclocks.
£49.99 inc VAT
Or even better...
£64.99 inc VAT
I think 550w might be little tight. If its going to cost £65 plus for a cheaper PSU I think I might get the AX750 for my new PC then use the old one to power this PC.
i wouldnt call the ax750 a cheap psu...but its brilliant, one of the best 750w psu out there
I wouldn't call it cheap either but if its for my main PC I'm happier to spend more ;)
I think you're underestimating a good branded PSU. For that sort of system 500w is more than enough. You only need 750w+ if you're planning a multi GPU setup.
On the other hand, that Hiper, is no way a decent brand. They have been known to take out the entire system when it's overloaded :eek:.
Your probably right, I just went by an online PSU calculator that said I need 567w - no idea how accurate they are :o
:eek: Hiper :eek: They used to burn well !
lol - never knew that, I've been running it for 4 years with dual 4890's
Great, so now maybe the smart move would be replace both PSU's?
At this rate the next thing I watercool will be my credit card :D
well not really, considering 1 ax750 = 2 cm silent pros ;p
Hiper is not bad really, it was one model and a specific wattage AFAIR. Other psus have had their bad models, some Enermax Liberty, Antec Truepower 430 and others suffering bad caps etc.., FSP Eplison etc..
