** Koolance @ Overclockers UK **
  • Thread starter Thread starter rjk
  • Start date Start date
rjk
rjk
OcUK Staff
8 Aug 2007
Coming soon to OcUK
A complete range of Koolance Fittings and WC hardware.
ETA is around a week. I will not be placing these as available for pre order but it should give you a good idea of the pricing and products.
any questions, just let me know in here.
Ordered...
Now. About those Swiftech Apogee II pump/blocks? ;)
as i have already said. swiftech are amazing at announcing products.
its just getting products to retaillers that is the problem
and a swiftech eta normally has a mathematical equation linked to it:
its best if I do it in Excel format
=SUM(Swiftech ETA:pricing of the product)* 189 Days
Nice size range there. Good work!
thanks, took me long enough to set it up :o
Damn it. Frosted EK Blasphemy it is :/
you will grow to like it....
in time.
whats flow like through qdc's please, been told the phobya are rubish
I can say with confidence it is a gajillion times better and that the phobya ones are absolutely useless.
Not only is the flow bad on the phobya ones I used, but with 2 of them and a moderate airlock in my rad (9x140) they were too restrictive for a D5 on max. They also leaked! LOL.
I have 2 of these:
http://www.overclockers.co.uk/showproduct.php?prodid=WC-054-KA
with counterparts:
http://www.overclockers.co.uk/showproduct.php?prodid=WC-061-KA
..and they are awesome imo. The phobya ones are fiddle and feel cheap, they spil liquid when you plug them together or take them apart. These things feel like the real deal and when you pull them apart you're left with barely... half a drop.
Shame I paid £4 more than ocuk's prices for each one.
Nice big stock list :D
Time to change out these absolutely huge heavy QDC's I'm using.
How big/heavy are the koolance QDC's?
@Cleee, afaik only EK have confirmed they are making blocks for the 7970 Lightning, I'm waiting for a reply from Gregor to see if they will be using the new or old design plexi.
The ones I have are about 9cm in length when joined. a big thicker than the tubing. Weight is hard to judge because of the tubing, but they are the dog's imo.
Cheers :)
The QDC's I have atm are that heavy that its starting to crush my tubing where it exits my case.
Here are my VLC4 (the largest size)
Any chance of the GPU-210 or 220?
