- 8 Mar 2007
Their support is excellent for a start. Also, the speed you sync at is determined by your line not your ISP. The speed you get is based on lots of other factors. Be get some of the best consistent transfer speeds on their network as well as not engaging in any traffic shaping.
And yet when I said it didn't matter who the ISP was you implied I was wrong earlier.....
ISP 1 might sync at 16Mbps and give you 15Mbps at peak times. ISP2 might only give you 4 or 5 at peak times.
...but now you are saying it's more down to physical factors like your phoneline, contradiction there bud. Well that phoneline will be the same whomever I use so my original point wasn't that inaccurate.
Small ISPs are more likely to fold when chased by rights agencies as well. If you want to use torrent sites etc you are probably more likely to get **** at a small ISP.
Small ISPs don't tend to get chased by the agencies because the effort takes more than the small number of customers you'll affect. That's why this High Court order only affects the big 6 companies, it has the biggest impact and sets a bigger example.
