Gigabyte Z68X-UD3H-Gen3 2 video outputs
Thats correct.
http://www.gigabyte.com/products/product-page.aspx?pid=3973#sp
1 x D-Sub port
1 x DVI-D port, supporting a maximum resolution of 1920x1200
* The DVI-D port does not support D-Sub connection by adapter.
1 x HDMI port, supporting a maximum resolution of 1920x1200
1 x DisplayPort, supporting a maximum resolution of 2560x1600p
Edit.. If you are unfortunate enough to be using a 2550K, then they dont have a built-in IGP so you cant use the motherboard to drive monitors.
Cool.
Just to add, despite the four outputs on the board, you can only use two at a time due to the Z68 chipset.
Sorry to hijack, but with these mobos im assuming its possible to drive the primary monitor from a discrete GPU and a secondary from the built in IGP to avoid clock speed increases?
Yes.
You can do say two from a Z68 board (if it has the right number of outputs) and one or two from a GFX card, but you cant do a stretched game across the screens like eyefinity etc.
