New PC parts chosen. Spec Sound Ok?
3 Aug 2008
Nelson, South Wales
Hi guys, im just about to order the following:
Intel Core i5 3570k, 155, Ivy Bridge CPU
MSI Z77A-G43 Mobo
MSI 2gb R7850 Power Edition GFX
650W Collermaster GX PSU
1TB Western Digital 3gb/s 7200rpm HDD
12gb Corsaid DDR3 XMS3 PC3-16000 RAM
Artic Cooling Freezer i30 CPU COOLER
24" ASUS LED MONITOR
What you guys think and will the components work well?
I got a case already. Only thing I do have really.. Is an SSD really worth it?
Once you got a taste of an ssd you can't go back...
plus, prices have droped a lot these last few weeks. It's very affordable now
Although I wouldn't go for 64GB, it's filled very rapidly. If I was you I would get the M4 120GB, or if you can stretch a little bit for 40£ you can have 240GB
YOUR BASKET
1 x OCZ Agility 3 240GB 2.5" SATA 6Gb/s Solid State Hard Drive (AGT3-25SAT3-240G) £139.99
1 x Crucial RealSSD M4 128GB 2.5" SATA 6Gb/s Solid State Hard Drive (CT128M4SSD2) £99.95
Total : £249.54 (includes shipping : £8.00).
Pinoneer DVR-S19LBK, SATA yes. Im going to order other little bits and bobs like a new keyboard and mouse, just listed the major things i wasnt 100%^ about..
1 x Intel Core i5 3570K,1155, Ivy Bridge, Quad Core, 3.4GHz, 5 GT/s DMI, 650MHz GPU, 6MB Smart Cache, 34x Ratio, 77W, Retail
1 x 2GB MSI R7850 Power Edition 2GD5/OC, 950MHz Core, GDDR5 4800MHz, DL-DVI-I/2xmini DP/HDMI
1 x MSI Z77A-G43, Intel Z77, S 1155, DDR3, SATA III - 6Gb/s, SATA RAID, PCIe 3.0 (x16), D-Sub/ DVI-D/ HDMI, ATX
1x 8GB (2x4GB) Corsair DDR3 XMS3 PC3-12800 (1600), Non-ECC Unbuffered, CAS 9-9-9-24, 1.5V
1 x 650W PSU, Coolermaster GX RS650-ACAAE3-UK, 85% Eff', 80 PLUS Bronze, SLI/CrossFire, EPS 12V, Quiet Fan, ATX v2.31
1x 120GB Sandisk Extreme, 2.5" SSD, SATA III - 6Gb/s, Read 550MB/s, Write 510MB/s, 83000 IOPS Max.
1 x 1TB Western Digital WD1002FBYS RE3, SATA 3Gb/s, 7200rpm, 32MB
1 x 1TB Seagate ST1000DL002 Barracuda Green, SATA 3Gb/s, 5900rpm, 32MB Cache, 12ms, NCQ
2 x 1m Akasa SATAII (300Mbps) Silver HDD Cable
1 x 24" Asus VS247H LED Black Full HD HDMI/DVI/VGA 1920x1080, 5ms, 300cd/m², 50000000:1
1 x Edimax EW-7722In 300Mbps Wireless 11n 32Bit PCI Adapter with Twin Antenna High Gain
1 x Sennheiser Home / HiFi Range RS120 Wireless Headphones
1 x Logitech G110 Gaming Keyboard, Custom Back Colour, USB Audio, Programmable + more
1 x Coolermaster CM Storm Spawn Gaming Mouse, USB2, 7 Button, 3500dpi
Choose Sata III or Sata 6GB/S, what you picked is outdated and will not use your motherboard to full potential, and 12ms seek time is a lot, 8ms are are pretty common and affordable.
http://www.overclockers.co.uk/showproduct.php?prodid=HD-257-SE&groupid=1657&catid=1660&subcat=
SSD only pick it if you have spare cash for it, you might want to invest those 100 pounds into better GPU or CPU since those things are non-effiecent to replace. You can always just buy a SSD and slide it in, especially as they are dropping prices as time goes on... You cant buy another CPU and use it with the other you already got on your motherboard.
http://www.overclockers.co.uk/showproduct.php?prodid=CA-165-CM
This is a great PSU for this price.
