** Coming soon to OcUK - Prolimatech Genesis Black **
rjk
rjk
OcUK Staff
8 Aug 2007
Hi Guys
Released today, one of the most incredible and unique CPU coolers on the market gets a makeover with the granite finish black coating that has proved so popular on the Megahalem.
We are expecting small allocations of this cooler initially so get in quick to secure your pre-order.
Prolimatech Black Genesis CPU Cooler (Socket LGA775/1366/1155/1156/AMD AM2/ AM2+/AM3) @ £69.98 inc VAT
Tower CPU heatsinks have been mainstream for the past few years. While power end users may consider them to be pinnacle when it comes to performance, there are others who would prefer down draft low profile heatsinks for their versatile ability to cool not just the CPU but also its surrounding components such as RAM, MOSFET, and Northbridge chipset heatsink. Genesis combines the best of both worlds with top-notch engineering design and superior built quality and performance that are surpassed by none. Either 120mm or 140mm can be installed on the Genesis for a maximum installation of 3 fans of your choice! If you are looking to overclock your CPU to the max while keeping your system stable, we highly recommend the ultimate CPU heatsink, Genesis. The New Era of Super Cooler has arrived
• Stylish black grainy matte finish for the best aesthetics
• High clearance for better motherboard compatibility.
• Massive cooling range; cools not only CPU but also MOSFET and RAM.
• Cooler surrounding temperature allowing more stable environment for higher overclock.
• Takes both 12 and 14cm fans for a maximum installation of 3 fans.
• Light weight at 800 kgs (without fans) in the highend class.
• Intel and AMD platform supported. All mounting hardwares are included.
Only £69.98 inc VAT.
ORDER NOW
Very light indeed :p
Isnt that going to hangover the RAM slots? how on earth would you change ram over if your upgrade or want to add more? would need to remove the Cooler. And the price to, bit much.
Seems to get a thumbs up in this review.
http://www.hardwareheaven.com/reviews/1170/pg9/prolimatech-genesis-cpu-cooler-review-conclusion.html
Semi decent conclusion.
http://www.legitreviews.com/article/1935/8/
I have to admit the more i see it, the more i like it. But its a fair bit behind in terms of temps against my h100 according to the 2nd review.
1st review is a little dated and the competition is hardly stunning tbh. Tried one out and was not that impressed, NHD-14, Phanteks, Silver Arrow or Mount Doom cooler would be a much better choice.
