hi all
just added an additional card to my rig:
my mo board is gigabyte x58a-ud3r, i7 930 o/c @ 4.0ghz and 3x2gb corsair ram.
the second card i have just added is an ati 5770 vapour-x. but it is larger than the one i already have. is this common? new revision?
since i installed this card both in pcie16x i am getting a rippled effect running down my screen. the bridge is connected on the one nearest to the back plate. hardware all shows up as it should, crossfire is enabled in ati catalyst. all seems fine apart from this rippled effect down the screen.
anyone had similar problem or any ideas to try correct this?
cheers all
cheers all
