- 11 Apr 2006
- Earth
At least it isn't Friday 13th today !!
Just built my i3570k system this morning in the CoolerMaster CM690 II Advanced (white)
Need to check off before turning it on:
1. CPU fitted correctly - check
2. CPU cooler fitted correctly - check
3. RAM fitted correctly - check
4. Motherboard chassis fitted correctly - check
5. GPU card fitted correctly - check
6. PSU fitted correctly - check
7. DVD-RW fitted correctly - check
8. SSD fitted correctly - check
9. HDD fitted correctly - check
10. SATA 6 cable for SSD - check
11. SATA 3 cable for HHD & DVD - check
12. SATA power cables for SSD & HDD - check
13. ATX power cable for DVD - check
14. Internal fans connected to mobo - check
15. Front button connections fitted correctly - check
16. GPU psu connection fitted correctly - check
17. Cable tidied around back - check
So, is there anything missing before I turn the thing on. I am actually scared haha haven't built a high end pc in 8 years !!
Also with SSD what do I have to set in BIOS to get it to boot and install OS on SSD drive, something about AHCI ??
Cheers
Cheers
