This is what I found going from a 80Plus to a 80Plus Gold PSU a while back. The gap between 80Plus and 80Plus Gold is actually a tad larger than the difference between Bronze and Platinum.
Code:
Before After Saving
Idle 166W 148W 18W - 11%
Load (P95&Furmark) 422W. 365W 57W - 14%
BFBC2 328W 296W 34W - 10%
Off. 5W. 2W. 3W
Sleep. 7W. 4W. 3W
So if we take the figures 2 hour at game load and 12 hours at idle load.
18W * 12h = 216Wh saved per day
34W * 2h = 68Wh saved per day
Total save per day 284Wh which is about 4p per day
Over a year the saving mounts to 103.66 kWh which is significant and is worth about £14.
A five year life span gives you a saving of around £70.
If my PC were running flat out 24/7 the figures would be quite different.
57W*24h = 1368Wh per day at around 20p saving.
Over a year that's £70 saving. If the PSU were to last 5 years it'd be £350 over the life of the PSU.
Your PSU may actually exceed the Platinum spec as well by a 1% or so.
So ultimately you save a little bit and if your usage and expected life span offsets the additional cost between a bog standard 80Plus Bronze and a Platinum it's all good.
I won my Gold PSU so the savings are just a bonus for me.
