- 20 Jul 2009
- The bleak North East arm pit of Britain
Hello!
OcUK have now got the brand new Corsair PLATINUM lines of the premium DRAM Dominator online ready to order.
There is no exact ETA at the moment however the OP (here) will be updated when I have an approx date for you all
Corsair Dominator PLATINUM 16GB (4x4GB) DDR3 PC3-15000C9 1866MHz Dual/Quad Channel Kit with DHX Pro Connector (CMD16GX3M4A1866C9) @ £179.99 inc VAT
The Corsair Dominator® Platinum builds on the legacy of the world’s most awarded high-performance memory, adding a striking new industrial design and LED lighting effects. Like all Dominator memory modules, they are built using only select memory ICs, highly-screened for performance and stability, and feature our patented DHX® (Dual-path Heat eXchange) cooling technology, so you can push them to the limit.
The new design will look great in your current system—or your next build—and the user-swappable light bar lets you customize the LED lighting to match your rig. You even can connect Dominator Platinum to the Corsair Link system to monitor temperature and activity. It’s memory with both muscle and finesse.
- Ultra-high performance 16GB (4x 4GB) Domintaor® PLATINUM Dual Channel kit
- 16GB total capacity provides ample headroom for the most demanding user
- Ultra-low 9-9-9-24 latency
- Intel XMP (Extreme Memory Profile) support
- Limited Lifetime Warranty
- Compatible with Intel X79, Z68 and P67 platforms
- Speed: 1866MHz
- Type: DDR3
- Format: DIMM
- Pin Out: 240
- Pin Voltage: 1.50V
Only £179.99 inc VAT.
ORDER NOW
Corsair Dominator PLATINUM 16GB (4x4GB) DDR3 PC3-19200C9 2400MHz Dual/Quad Channel Kit with DHX Pro Connector (CMD16GX3M2A2400C9) @ £299.99 inc VAT
- Ultra-low 9-11-11-31 latency
- Speed: 2400MHz
- Type: DDR3
- Format: DIMM
- Pin Out: 240
- Pin Voltage: 1.65V
Only £299.99 inc VAT.
ORDER NOW
Corsair Dominator PLATINUM 16GB (2x8GB) DDR3 PC3-15000C9 1866MHz Dual Channel Kit with DHX Pro Connector (CMD16GX3M2A1866C9) @ £199.99 inc VAT
- Ultra-high performance 16GB (2x 8GB) Domintaor® PLATINUM Dual Channel kit
- Ultra-low 9-10-9-27 latency
- Speed: 1866MHz
- Type: DDR3
- Format: DIMM
- Pin Out: 240
Only £199.99 inc VAT.
ORDER NOW
Corsair Dominator PLATINUM 8GB (2x4GB) DDR3 PC3-17100C9 2133MHz Dual Channel Kit with DHX Pro Connector (CMD8GX3M2A2133C9) @ £134.99 inc VAT
- Ultra-high performance 8GB (2x 4GB) Domintaor® PLATINUM Dual Channel kit
- 8GB total capacity provides ample headroom for the most demanding user
- Ultra-low 9-11-10-27 latency
- Speed: 2133MHz
- Type: DDR3
- Format: DIMM
- Pin Out: 240
Only £134.99 inc VAT.
ORDER NOW
Corsair Dominator PLATINUM 8GB (2x4GB) DDR3 PC3-15000C9 1866MHz Dual Channel Kit with DHX Pro Connector (CMD8GX3M2A1866C9) @ £89.99 inc VAT
- Speed: 1866MHz
- Type: DDR3
- Format: DIMM
- Pin Out: 240
Only £89.99 inc VAT.
ORDER NOW
Corsair Dominator PLATINUM 16GB (2x8GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit with DHX Pro Connector (CMD16GX3M2A1600C9) @ £169.99 inc VAT
- Speed: 1600MHz
- Type: DDR3
- Format: DIMM
- Pin Out: 240
Only £169.99 inc VAT.
ORDER NOW
Corsair Dominator PLATINUM 8GB (2x4GB) DDR3 PC3-12800C8 1600MHz Dual Channel Kit with DHX Pro Connector (CMD8GX3M2A1600C8) @ £89.99 inc VAT
- Ultra-low 8-8-8-24 latency
- Speed: 1600MHz
- Type: DDR3
- Format: DIMM
- Pin Out: 240
ORDER NOW
Corsair Dominator PLATINUM 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit with DHX Pro Connector (CMD8GX3M2A1600C9) @ £82.99 inc VAT
- Speed: 1600MHz
- Type: DDR3
- Format: DIMM
- Pin Out: 240
Only £82.99 inc VAT.
ORDER NOW
- Speed: 1866MHz
- Type: DDR3
- Format: DIMM
- Pin Out: 240
ORDER NOW
- Speed: 2400MHz
- Type: DDR3
- Format: DIMM
- Pin Out: 240
ORDER NOW
- Speed: 1866MHz
- Type: DDR3
- Format: DIMM
- Pin Out: 240
ORDER NOW
- Speed: 2133MHz
- Type: DDR3
- Format: DIMM
- Pin Out: 240
ORDER NOW
- Speed: 1866MHz
- Type: DDR3
- Format: DIMM
- Pin Out: 240
ORDER NOW
- Speed: 1600MHz
- Type: DDR3
- Format: DIMM
- Pin Out: 240
ORDER NOW
- Speed: 1600MHz
- Type: DDR3
- Format: DIMM
- Pin Out: 240
ORDER NOW
- Speed: 1600MHz
- Type: DDR3
- Format: DIMM
- Pin Out: 240
ORDER NOW
