Caporegime
- 18 Sep 2009
- Dormanstown.
I recall Martini1991 being a long time AMD users...and with him jumped boat, went Intel and now recommend you this he knows what he's talking about.
I think as Martini1991 says,the Core i3 2100 would have been a good choice in the first place. I have one,but TDP was the main reason,as my rig is quite small and the lower TDP SB CPUs were silly money. Luckily,IB is not so bad in that regards,so I will eventually change over to them.
Skyrim is demanding as it uses only two threads. However,have you tried to play around with the settings and drivers,to see if you can improve peformance?
Silly question - I assume you got a decent PSU when you bought the rig? If you are changing over to an overclocked HD7850 2GB,it will still consume more power in that state than your HD6850.
Oh God, please don't remind me.
I did the whole AMD thing, AM2+ Phenom II, over to an AM3 790FX board, over to an AM3 890FX board when I simply couldn't go ahead anymore, my 6870's were so ridiculously bottlenecked by my 1055T at 4.37GHZ it was getting silly, I gained 40 FPS in Dawn Of War 2 going to a 2500k.
I used to justify it with "Yeah, but you can't tell the difference".
If I'd have gone Intel straight off the bat I'd have saved rather a lot of money.
Also, Phenom II was Core 2 IPC (or around there) with the FX4100 being slower than Phenom II clock for clock, a 3.6GHZ should best an FX4100 in a lot of situations, there's almost half a decade between the CPU's too.
shame really, I quite like the company and all. I'll go Intel when I have the £££.
So I really shouldn't of even gone AMDshame really, I quite like the company and all. I'll go Intel when I have the £££.
It's not that they're "bad", it's just they're not as good as Intel, and their latest line up is a disgrace.
Lowering their own price/performance in some instances.
AMD can be good if second hand, take a Phenom II X2 BE, you can pick them up for like 30-40 quid, some can unlock to full fledge Phenom II X4's, overclock one to 4GHZ and that's incredible performance for the money.
I prefer higher AMD tier boards, take this ; http://www.overclockers.co.uk/showproduct.php?prodid=MB-461-AS&groupid=701&catid=1903&subcat=2046
Lovely looking board, to get that type of board (Which I have) costs insane money;
http://www.overclockers.co.uk/showproduct.php?prodid=MB-475-AS&groupid=701&catid=5&subcat=1990
I have the P67 variant though.
EDIT : The FX line are really bad on Skyrim aren't they? CPU limited like hell by all accounts.
Cool! Your PSU would be enough for two HD7870 cards let alone a single HD7850!!![]()
I can crossfire on this motherboard and this processor right?
Step 1) Upgrade to Intel i5
Step 2) Upgrade to HD 7850
Step 3) Crossfire to 2x HD 7850
Step 4) ???
Step 5) Enter the Matrix.
You might not need to upgrade you 6850 just yet if you are ok with playing games with slightly lower graphic settings.So long story short, I should upgrade to an i5 sharpish and then look for an 7850 afterwards? I'd say short term (until about August) I can afford one or the other, so logic would have me upgrade mobo+proc first?
To help you get a clearer idea on graphic card vs CPU, let me put it this way...
If you had a fast CPU that's capable of deliver 60fps+ but your graphic card can only deliver 25-40fps at max graphic settings, you could always reduce graphic details to help improve frame rate and push it closer toward 60fps;
but if you had graphic card that can do 60fps+ at max setting, but CPU is only capable of delivering 30-40fps, then there's much you can do to push the frame rate to above 30-40fps, and adusting graphic settings won't help.
Hope this make sense to you.
CPU can limit performance regardless of the graphical quality, whereas a GPU can only increase performance if the CPU can actually cope with it aswell. I'd say a CPU is a more integral part of the machine then.You can probably overclock that 6850 to 950MHZ using Asus GPU Tweak (Has quite a VRM library)
I run my brothers 6850 at 950MHZ with a Pentium dual core G620.
I'm stupid when it comes to hardware but I get the theoretical'sCPU can limit performance regardless of the graphical quality, whereas a GPU can only increase performance if the CPU can actually cope with it aswell. I'd say a CPU is a more integral part of the machine then.
Are you talking about my graphics card from my other thread? I'm using the CCC at the moment, it seems to do the job.![]()
OP needs Windows 64 bit too.
You'll have 10GB of RAM with a 7850 (2GB G card, 8GB system) 32 bit (x86) can only address 4GB total, so your Skyrim issues may/may not be RAM limitation but I doubt it.
But you will likely encounter issues with the 7850 2GB if you don't get 64 bit.
Thankfully Windows 7 32 bit keys and interchangeable with 64 bit keys.
I have 8GB system RAM, DDR3 @ 1100Mhz I think?Cool! Your PSU would be enough for two HD7870 cards let alone a single HD7850!!
Strange issue,you are having - I assume you didn't pour some Skyrrum onto your PC:
http://greatcocktailrecipes.blogspot.co.uk/2012/01/elderflower-scrolls-skyyrum-elder.html
So,even after you re-installed the game,it started to have issues?? Maybe a game update or driver update has broken something?? Have you had a look on the Bethsoft forums or any of the dedicated Skyrim ones?? Its worth a look.
that drink looks awesome!
) and then I got the 2K Texture Pack FULL which is something like 4096x4096 resolution which is huge compared to the official HD texture pack which is 2048 x 2048 and ran it with a 'summer' ENB on ULTRA (I kid you not, I ran it on ultra as those were the settings it detected for me) and it ran fine, wasn't perfect, had some stuttering etc. but definitely playable. Then I got the official HD texture pack off Steam and installed that and BOOM, my entire experience went to **** and could barely run it, it was 30+ fps on average but the amount of stutters when I panned the camera was immense.MSI Afterburner is better for overclocking AMD cards.
My bad, I have 64 bit, I thought x86 was the smart mans way of saying 64 bit.![]()
Isn't that just for temp monitoring during gameplay?
Damn, thought I was being awesome.
32 bit is X86 and 64 bit is X64.
how come?
Nah.
It's one of my preferred OC'ing tools, but it has quite a VRM library limitation in regards to none reference cards and the developer is an arrogant *****.
No point in changing that CPU for another amd chip, just wasting cash. Either stick with what you have or do a complete Intel rebuild.
shame though that AMD have to fall so far behind when it comes to end game.
Strange that 32 bit has a higher number as an X or whateverhow come?
VRM Library? I feel so stupid.![]()
Couldn't tell you on the first part, and second part, VRM is voltage regulation, to increase voltage, which is paramount for getting higher overclocks.
So I'm better off using CCC to overclock and MSI to monitor ingame temps? I don't mind using two programs, I use about 5 to mod Skyrim.![]()
No.
Use MSI to do both.
CCC can't overvolt.
MSI can overvolt, but doesn't have the same VRM compatibility as GPU Tweak/Sapphire Trixx.
