Going to make mounting difficult with only 2x holes for fittings surely?
Nice one
They are absolutely hideous to look at though ..
There will be another set of holes on the underside as usual with EK blocks.
The 670 block will be half the price of the 690 right?![]()
Are you sure? the 680 block doesn't appear to (or am I missing something?)
http://www.overclockers.co.uk/showproduct.php?prodid=WC-213-EK&groupid=962&catid=1520&subcat=
Be sure you understand that using a block on the 670 won't improve it's overclocking ability.
These cards just like the 680's are voltage limited and not hindered by cooling.
Buying one thinking it will increase your overclocks is going to be a disapointment.
There will be another set of holes on the underside as usual with EK blocks![]()
from what i understand they arent doing that any more
probably to encourage sales of their sli bridge/link thing
Rather lame tbh. makes it quite impossible to have a somewhat tidy loop if your not SLI'ing.
This.
Not very impressed by this move tbh, they could at least include a fitting to allow you to route tubing in the opposite direction, like a dual 90 rotary.
