Affordable Cooler Express Cools CPU @ -48C & 980x OC'D @ 5GHZ at 20C
Priced at $800, I've seen it cooling 980x on idle at -12C but on the website it states it can cool at -48C.
The overclocked tempretures of the 980x at 5ghz speak for themselves.
I dont know if im allowed to link a product to another website but it is frozencpu.
A good alternative for liquid nitrogen for extreme overclockers but obviously not the MOST extremists ?
" The Cooler Express 2011 Design Super Single Evaporator CPU Cooling Unit is the all new 2011 model - featuring compatibility with all modern sockets, a simple, single CPU cooler design and extreme cooling (-48°C)!
The unit attaches to the bottom of your case and the evaporator tube snakes through the bottom of your case (after a hole has been added) and mounts directly to the CPU. With temperatures way below freezing, you can overclock your CPU far beyond what is possible even with the best water cooling!
Simplicity and ease of use were incorporated into the new units. These new 2011 units have a modern sleek design and have eliminated the control board which most users found a nuisance. A front power button was incorporated to make powering on the unit easier as well. The compressor is a larger more robust version with a 180W - 200W dissipation rating. Some reviews have seen up to 280W! "
