Need FAST HELP! << Motherboard which one!?
Status
Not open for further replies.
14 Jun 2012
Ok, I'm in need in rapid help, I have 2 options:
ASUS P8Z68-V PRO/GEN3, LGA 1155, Intel
OR
Gigabyte Z77X-D3H Intel Z77 (Socket 1155) DDR3
OR
GIGABYTE GA-Z77-DS3H Intel Z77 (Socket 1155)
OR
Asrock Z68 Extreme4 Gen3
Which one should I go for??
I have:
Intel i5 2500k
Radeon 6870 (I wish to crossfire soon)
2x4 gb of Ram
I'm looking to add Minimum 3 fans on my system
The second one.
Better warranty/uk based RMA centre, good overclocking abilty, features, does crossfire+sli at 8X/8X
None of those I would get the Gigabyte Z77 D3H (less than £80) - check out the Gigabyte's website and ensure you are not paying for features that you do not need but get the ones you do.
But the OP wants the option of Crossfire and the one you suggest only does it at the inferior 16X/4X bandwidth.
Help me choose between these Two Motherboards ^_^
I now have only 2 Options left, earlier I had 4:
Gigabyte GA-Z77X-D3H
VS
ASROCK Z68 EXTREME3 GEN3 Intel
Which one should I get and Why?
I want to use it for gaming with i5 2500k, Radeon 6870 Crossfire - Might change to Nvidia so SLi included which one is best overall?
The Gigabyte,
3 year warranty.
UK based RMA center.
Great build quality
Well received in reviews.
Thanks, how about:
Or
gigabyte ga-z68ap-d3
- Sorry for being so picky, it's my first build and I want to be future proof
The AP-D3 maybe cheaper (and currently includes a free 16GB USB stick) but it lacks SLI support and only does Crossfire at 16X/4X bandwidth for the two slots, the Z77X-D3H does both SLI/Crossfire at 8X/8X so both cards get the same slice of the pie.
But the AP-D3 has some good reviews also,
Side by side comparison - http://uk.gigabyte.com/products/comparison/list.aspx?ck=2&pids=3897,4144
Last and FINAL Question :)
Gigabyte GA-Z77X-UD3H
Or
What's the difference?
Which is better?
-I apologise I'm just filtering out which motherboard to get :) Getting one 4am this morning
The UD3H has extra,
Esata ports
Displayport
Bios switch
Power, reset and Clear cmos switches
Voltage measuring points.
There maybe some other difference I can't remember.
Use the comparison link I gave in your other thread to select and compare.
For future reference it's better to keep all your questions in one thread, it means you're more likely to get people to respond as they may miss new threads but also it avoids duplicating threads unnecessarily.
Status
