Western Digital Scorpio Blue 750GB.
Hey John, right above is the HDD you have, l assume you made a couple of backup DVD's when you first got the laptop? If not download a legal copy of the relavant Windows 7 OS (ie 32 bit or 64 bit).
1. Do you have the recovery disk?
If not then.
2. If Win 7 then download this legal iso of windows 7
http://www.mydigitallife.info/official-windows-7-sp1-iso-from-digital-river/. Select your flavour 64 or 32 bit.
3. Use
Windows 7 USB/DVD Download Tool to create a bootable USB stick (8GB to 16GB required).
4. Once installed use key on bottom of laptop.
5. If none of the above is doable then l suggest
Ubuntu 12.04/
Kubuntu 12.04 or
Linuxmint as alternative OS's.
Place you old HDD into the caddy below or a caddy you can get your hands on, once done connect to laptop and see if you can get the files off.
Lian Li EX-10QI 2.5" External USB3.0 HDD Caddy.
If you are unable to get the files off, there are companies that can, however it does cost
Regards.
C.
