16 Jun 2012 at 10:24 #1 Shady45 Shady45 Associate Joined 10 Jun 2012 Posts 239 It comes with the gelid tranquillo, was wondering if anyone has any experience with it and whether I should buy a different one?
16 Jun 2012 at 10:38 #2 doyll doyll Soldato Joined 1 Jul 2011 Posts 8,807 No personal knowledge. TechPowerUp tested it with same results as MX-2 Bjorn3D thought it was good.
16 Jun 2012 at 10:42 #3 panyan panyan Soldato Joined 13 Mar 2011 Posts 7,484 Location Bada Bing if it is branded - it should be fine
16 Jun 2012 at 11:14 #4 Shady45 Shady45 Associate OP Joined 10 Jun 2012 Posts 239 I read a few reviews and it seemed pretty good, but one said they had trouble cleaning it off and bits were left or something. Think I will just stick with it rather than buying another one. Thanks
16 Jun 2012 at 12:32 #5 Helios1234 Helios1234 Soldato Joined 9 Jan 2008 Posts 6,513 Location London/Camberley It's not great. I don't understand why Gelid don't bundle the gc extreme which is much better...
16 Jun 2012 at 14:19 #6 Shady45 Shady45 Associate OP Joined 10 Jun 2012 Posts 239 I guess I can try it and if there are any problems, remove it and then use another one?
16 Jun 2012 at 15:24 #7 doyll doyll Soldato Joined 1 Jul 2011 Posts 8,807 Shady45 said: I guess I can try it and if there are any problems, remove it and then use another one? Click to expand... Yeah, a little alcohol and cotton buds. Keep some paper towels hand. I swear these pastes will jump 40mm to get on things.
17 Jun 2012 at 20:31 #8 Shady45 Shady45 Associate OP Joined 10 Jun 2012 Posts 239 Thanks, I will make sure I keep some handy
