Best 650-700W Power Supply?
You want a PSU with four PCI-E connectors ideally for Crossfire of 6870 as you mentioned in the other thread, or you use molex-PCi-E adapters that came with the cards?
These PSU's have enough power/good quality and four PCI-E connectors,
http://www.overclockers.co.uk/showproduct.php?prodid=CA-002-XF&groupid=701&catid=123&subcat=
http://www.overclockers.co.uk/showproduct.php?prodid=CA-054-BQ&groupid=701&catid=123&subcat=
http://www.overclockers.co.uk/showproduct.php?prodid=CA-047-CS&groupid=701&catid=123&subcat=
http://www.overclockers.co.uk/showproduct.php?prodid=CA-055-BQ&groupid=701&catid=123&subcat=
The PSU's are also partially modular so you can detach some of the cables to easy cabling in the case.
650w should be enough, Guru3D reckon 700w and thats with them testing with a more power hungry older socket1366 test system.
http://www.guru3d.com/article/radeon-hd-6850-6870-crossfirex-review/4
Radeon HD 6870 x2
A second card requires you to add another ~150 Watts. You need a 700 Watt power supply unit.
A Sandybridge 2500K like you are after uses less power than their test system:)
Wow you're everywhere today lol :D Thanks a lot! I'll consider them :) What about the OCZ PSU ZS 750W 80+ Bronze? Is that good or bad O.o
