Card for AutoCad 2013
27 Oct 2006
London
Here we go again....
Anyone using a gaming card for Cad or should I go for quadro/firegl ?
Ideally I would like the best of both worlds - gaming and CAD but am uncertain that it would work
I know the feeling, for the price of a GTX 680, you are getting old tech like an 8800gtx with superior CAD drivers and guaranteed compatibility.
I usually spec the PC's for our drawing office and with the last few have gone with the Quadro's.
Im using a Gaming card (GTX 460) to do CAD work on my home PC. It is perfect. CUDA is a great addition.
Also used quadro card on my placement only a FX1700 (i think). Perfromed OKay, but not as good as my 460. Though ther 460 is a lot better anyway.
Im guesssing the higher end Quadros are better but a lot more expensive than gaming cards. They cannot really be used for gaming either, as they don't have the Power.
If going for a gaming card, CUDA support and CUDA cores are vital.
