- 10 Jul 2006
I have a new freezer and there is lots of ice in it....so much so I can't open the drawers.
What could be causing this?
temperature setting too low?
That would be my guess as well, moisture is getting in somewhere.air leak probably, door not shut properly at some point, or door rubber leaking air past it
maybe you need to get your car and attach a string and then drive the car away, then remove the ice
Rinse and repeat
Usually the highest setting(/max) would mean the coldest temperature, not the highest temperature.It's set at the highest setting (so highest temperature)
Can one simply buy a new seal for the door? My freezer is similarly full of ice & I'd like to replace said seal. The landlord simply wont bother though- so where do I look to buy a new one and does it simply glue on?
Actually I looked at this the other week, it's stupidly expensive (circa £50) and not worth it. Only about £2 worth of materials tooCan one simply buy a new seal for the door?
