Hi All,
Looks like I've secured funding to update my long in the tooth PC. I'm planning to put this lot in my existing Lian-Li PC-7 case. Surprisingly the 7850 is allegedly only 197mm long so should fit in nicely. I'm thinking of using the stock cooler initially as I'll run it for a while at stock speeds. Once the missus has forgotten just how much I spent on the rig I'll upgrade the cooler and consider overclocking.
I've gone for 3 monitors as this works well with FSX where the extra peripheral view helps. For more modern games I'll probably have to just use the center screen to keep the performance up. One question with the eyefinity set up, the monitors have display port connection but the card have mini-DP. I've had a good look around OCUK but haven't spotted and cables that go from Mini-DP to DP am I missing something?
Finally have I missed anything? I have a SATA DVD RW to pop in from the old rig and a couple of Seagate Barracuda 7200.10 250GB SATAII HDD should I need any more storage.
YOUR BASKET
1 x MSI HD 7850 Twin Frozr III OC 2048MB GDDR5 PCI-Express Graphics Cards £199.99
1 x Intel Core i5-3570K 3.40GHz (Ivybridge) Socket LGA1155 Processor (77W) - Retail £189.95
3 x Dell UltraSharp U2212HM 22" Widescreen LED Monitor - Midnight Grey £179.99 (£539.97)
1 x Crucial RealSSD M4 256GB 2.5" SATA 6Gb/s Solid State Hard Drive (CT256M4SSD2) £166.99
1 x Cooler Master GX 750W '80 Plus Bronze' Power Supply £79.99
1 x Gigabyte Z77-D3H Intel Z77 (Socket 1155) DDR3 Motherboard £79.99
1 x Microsoft Windows 7 Home Premium SP1 64-Bit - OEM (GFC-02050) £79.98
1 x Seagate Barracuda 7200.12 1TB SATA 6Gb/s 32MB Cache - OEM (ST31000524AS) £69.98
1 x Kingston HyperX RED Limited Edition 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX1600C9D3B1RK2/8GX) £43.99
Total : £1,467.04 (includes shipping : £13.50).
YOUR BASKET
just be careful with them Ivy they get very hot when being pushed hard!
Seeing as my existing PC is :-
