Ivy Bridge / Z77 Platform - 16GB Ram Dual/Quad clarification
29 Dec 2003
UK
My home Pc is still 775 platform so am a newb on Sandy/Ivy bridge and all things DDR3.
Im speccing up a new CAD PC for work and want to use 16GB of ram.
Im thinking of using a GA-Z77-D3H motherboard and the spec says it uses Dual channel memory.
Can someone clarify what my option are for 16GB.
Do I need 2 x 8GB dual, 4 x 4 GB Dual or 4 x 4GB quad channel. Not sure what the difference is between the latter two but some ram is sold as that.
One more thing, If I was to do a simple overclock with a 3570K to 4-4.2 Ghz does having 4 x 4GB make it any harder to achieve over 2 x 8GB. And also would getting DDR3 1833/ 1600 over 1333 make it any easier to make stable?
Cheers
What graphics card did you have in mind ?
Now thats the million $$ question.
As a company we are moving onto new software. Tekla Structures . It used openGL but Its hard to find out exactly whether the superior drivers on Quadro/FireGL card is any extra benefit over the extra grunt on an equally priced mainstream card. We are on a budget so will be looking in thw £200-300 range for graphics.
