Permabanned
- 9 Jun 2009
- London, McLaren or Radical
How was this done?
Take a photo -> Photoshop -> Filter menu ->
And it's one of the "artisitic" / "brush strokes" filters
How was this done?
Looks like the window has a blind, I reckon he just opened it for the picture![]()
Just bought a new desk !
A little bit disappointed though because the keyboard shelf is too narrow, not a lot of space for gaming with the mouse
Don't you think it's a bit of a gimmick having analogue tube-amp driven sound when it's (presumably) running digital audio files? Get a turntable and it makes sense. Harsh digitally encoded mp3's and FLAC have terrible frequency flattening.
What mrk said in the main, plus you can get remastered FLAC files quite commonly too (i.e. the same as the Vinyl mastering)
Why would that matter? You don't know what soundcard he has, could well be using a decent DAC too. The amp will output to the speakers a nicer sound from the music regardless of source format.
Plus, FLAC (lossless) or at the very least, 320Kbps/LAME is just fine.
The issue here really is the odd speaker placement, you're not going to get the best sound by having the speakers aimed at nothing![]()
Seeing it plugged in a PC anyway is painful
FLAC still makes high-end sound overly crisp and unavoidably digitized, even if it is ripped from a 'vinyl mastering'; it's the digital format as much as anything else. If you want the best digital format for quality dynamic ranges in the waveform, go for .wav. Still won't be that good, though. And still senseless having an 'analogue' soundcard in my opinion if you are playing a digital source-file.
From what I've sampled - various DACs make a massive difference!Also I fail to understand mrk's point about having a quality DAC. 24-bit/96000hz is pretty much the standard for any decent mid-range sound-card and it doesn't make that much of a difference if you're still playing **** you downloaded from torrents.
Fair point - but then you also need to consider the type of music that someone listens to.@crinkle the problem isn't so much FLAC, it's the digital file format and the way tracks are mastered for it. Waveforms are just chunked out to huge rectangle blocks, lows and highs are edged off and muddied. Digital music is just one big compromise, really; it's rarely done right. The tendency nowadays is for digital tracks to be louder and louder and with no real dynamic range, which is why being particular about analogue gear can sometimes by a fruitless task. Seeing it plugged in a PC anyway is painful![]()
Your GS 3 almost matches the colour of your wallpaper there!![]()
I'm a total vinyl purist. PC sound - audio qualms notwithstanding - is just such a soul-less exercise. The way you acquire it, the way you 'play' it, the way you engage and listen (or rather don't listen) to it... it just relegates music to background sound for other primary tasks (e.g. browsing, gaming, reading, etc). It removes the primacy and actuality of music. Vinyl for the winHave my 1210M3D on the desk right next to my computer monitor, for easy changes, haha.
Digressing now anyway, back on topic...
Maybe this applies to someBut for most it's perfectly fine and quite enjoyable too once set up right. I know my setup doesn't have any harshness but I spent the good part of a year trying different floorstanders, upgrading sound cards and then trying different stereo amps before going back to the NAD C325 Bee.
Music is subjective though, and I like the the sound NAD amps give off but they're quite picky with speakers and at present I'm really liking them paired with the Tannoy V4. Combined with the Essence STX and upgraded Opamps, I experience a nice warm sound with plenty of detail across the range and absolutely no harshness!
Of course, I'm no die hard when it comes to audiophile business, I just like to enjoy crisp, natural sounds when playing music and watching movies![]()
