Thats all very well and good....but what do they then use such a creation for?
WHAT DOES IT MEAN?!![]()
OUR MISSION
Lawrence Livermore National Laboratory has a mission of strengthening the United States’ security through development and application of world-class science and technology to:
Enhance the nation’s defense;
Reduce the global threat from terrorism and weapons of mass destruction;
And respond with vision, quality, integrity and technical excellence to scientific issues of national importance.
From their website.
But can it run Crysis?
[FnG]magnolia;22167654 said:Imagine what Skyrim would look like on it![]()
the same as it does everyone elses pc...
It's based on the BlueGene architecture so it's massively parallel POWER7 CPUs, that makes puts it between 3.5GHz and 4.5GHz depending on the exact CPUs they've used. Memory is 1.6PB spread across 1.6 million cores (up to 8 cores per physical processor) so it's not likely to be paging!Probably around the same Ghz you would get in a regular machine tbh. it won't be more than 4Ghz, due to the heat 1500 cpu's would put out.
As for ram, well, quite a lot more i would think. I'd say in the Terabytes area tbh, heck could be more![]()
[FnG]magnolia;22167654 said:I've just been reading this article from the BBC and am struggling to get my head around the above quoted paragraph. I imagine they've used that comparison to provoke that very sense of 'woah!' but I wonder how the supercomputer would compare to, say, a mid-range home PC? Regardless, those are some pretty bonkers stats.
You can't compare it clock for clock, so it isn't really 'the same as a regular machine'.Probably around the same Ghz you would get in a regular machine tbh. it won't be more than 4Ghz, due to the heat 1500 cpu's would put out.
Little bit outAs for ram, well, quite a lot more i would think. I'd say in the Terabytes area tbh, heck could be more![]()
