- 26 Jun 2005
How are you restoring your applications? From disc and DMG's? Is it possible to restore applications from Time Machine or Carbon Copy Cloner backups?
Sorted it thanks guys. I had to format it first (forgot you had to do this). I also set a hard drive partition for the recovery console. Hope thats right.
Installed it now, cant believe how quick this thing is now!
How did you set the recovery partition? Should just use the option in CC, if you created it manually, this is wrong.
What device list exactly? Time Machine doesn't have a device list.Right I think I have a problem. I cant back up using time machine. Its not seeing the SSD in my device list?
Any idea whereI have gone wrong?
He's already purchased, see above.Although I have an Intel 510 120GB in my MBP I'd go for
Crucial M4 -> If your on a budget
Intel 520 -> If your wanting the best of the best
