Are the pre built cases worth it?
21 Jun 2005
Looking at building a new PC but I want to have it under watercooling.
I've been looking at http://www.overclockers.co.uk/showproduct.php?prodid=WC-004-CM&groupid=701&catid=7&subcat=2087
From what I understand it has all the relevant bits to cool my CPU? However I'm looking at overclocking my future 680 GPUS, is it going to be hard to add to the current setup so that it can cool 1 or 2 GPUS?
Never built a watercooling system before and must admit rather scared which is why I like the idea of the above link.
Thanks
If your going to add to the loop its best to do it yourself to begin with as your going to have to take it apart, change coolant, and put it back together if your adding gpu blocks. You will need the experience ;)
Case is £140 and the V12 water cooling kit is £284
Total =£424
Water cooled case cost £445
£21 for fitting and gaurented
Suppose when you look at it like that :D
Ok, guess I may not have water cooled GPUs :)
