Inventions only mean something when the inventor can make it available to the public at a reasonable price. Until then it is just pie in the sky.
So all space travel means nothing?
lolgroen
lolgroen
Space travel as a whole, yes. But space travel is not one invention, it is many many inventions which are indeed made available to the public.
So lolkrooton![]()
Something smells fishy.
Where can I buy a space shuttle pls? Going to the moon, brb, lol!![]()
Maybe it is simply ignorance.
Most journalists probably know nothing about physics. The average man on the street doesn't care either because he knows nothing about fusion.
hydrogen + nickel => copper
you can buy a pen that works in zero mavity.
or just do as the russians and use a pencil![]()
yay this myth again.
while a pencil will work it is not practical in space. if the lead broke in zero mavity it would float around the spacecraft and could get into and break important electronics. i'm 99% sure the russians did not use a pencil in space but they may have tried it and found this exact problem.
also, while the americans spent a lot of money developing a pressurised pen*, according to QI, a normal biro would work in space as it does not need mavity, so a pen that will work in zero mavity isnt that special
*again, 99% sure they did but happy to be proved wrong here
In December 1967 he sold 400 Fisher Space Pens to NASA for $2.95 each
It might sound plausible if you know very little about fusion, but it sounds extremely implausible if you know more than a very little.
The Ecat probably consists of a solution of nickel ions, a palladium catalyst, hydrogen from electrolysis and acoustic cavitation.
Using nickel must somehow increase the collision rate.
Urban myth, as far as I know. Good story, but probably not true. Besides, little flakes of graphite floating around in zero g amongst delicate and critical equipment is a problem.
I understand the scepticism of course, but why would someone run such a long con. If he's pulled in money from investors, why would you run the risk of being found out by creating test, .
article said:INFORMATION:
AFTER THE LEAKAGE MADE BY AN INSIDER WITH THE NICKNAME “CURES” REGARDING THE TESTS COMPLETED ON JULY 16TH, WHICH HAD TO REMAIN UNDER NDA, I HAVE TO INFORM THAT:
THE TEST MADE ON JULY 16TH WILL BE REPEATED OFFICIALLY WITHIN THE HALF OF OCTOBER 2012 BY THE UNIVERSITY OF BOLOGNA, AND THE RESULTS WILL BE PUBLISHED BY THE SAME UNIVERSITY.
ANDREA ROSSI
