** Koolance @ Overclockers UK **
  • Thread starter Thread starter rjk
  • Start date Start date
20th June and it's still showing as "In our warehouse queue"
Any updates guys? I know I pre-ordered, but you said these were in (or at least Koolance stuff was in) last Friday.... Any longer and I'm going to cancel my order...
Couldnt wait anymore and went for some of these in matt black :)
I have now... As someone was responding here I've kept any questions here assuming that someone would take it up if there was a problem.
Yay! Finally checked in and despatched! I'll photograph unboxing and post up my findings when they arrive.
Thanks OCUK!
They certainly look a piece of beauty. Any chance shomeone could do an install guide/vid for these fittings. I've had a quick look on Youtube, but couldn't see anything
skip to 2:00 to see them being used rather than just fondled by the dippy albeit lovely lady
I googled "monsoon fittings video" and this was the 2nd link at the top of the page by the way :rolleyes:
Thanks OCUK!
I bought some and will be installing them in my build over the next weekend/week.
Link in sig :)
i only searched in Youtube. That'll teach me. Your Google powers are strong my friend..... ;)
So yesterday I received the VL3 and VL3N barb male/female fittings.
I'm disappointed to report that these definitely are NOT compatible fittings (VL3 & VL3N)
The barrel or the male
http://www.overclockers.co.uk/showproduct.php?prodid=WC-076-KA
is too wide to fit inside the female
http://www.overclockers.co.uk/showproduct.php?prodid=WC-084-KA
I guess you have to match male VL3 to female VL3 and vice versa with VL3N's.
OCUK's excellent customer service raised the RMA and back they've gone. Shame
Having got my hands on the kit though, it certainly it VERY nonrestrictive (if you push the valve in either component in, and then blow through the fitting) - definitely leaps and bounds better than the Phobya ones - (don't for pity's sake buy those unless you need to cripple flow in your rig)
Gutted at the outcome, but delighted with OCUK's help in the matter.
Sorry. Will try and sort this. I used the Koolance setups for these so if it is unclear then it was written like that on their website.
I will try to make things a little more clear on OcUK now
from koolance
Koolance (patent-pending) quick disconnect no-spill coupling with automatic shutoff. 13mm (1/2") ID female hose barb with clamp. It will only fit any Koolance VL3N High Flow male shutoff valve. After a quarter twist, the quick-disconnect nozz ...
Koolance (patent-pending) quick disconnect no-spill coupling with automatic shutoff. 13mm (1/2") ID male hose barb with clamp. It will only fit any Koolance VL3N female shutoff valve. After a quarter twist, the quick-disconnect nozzles will s ...
the N series and the non N series are not compatable from the koolance webby..
but yup its not obvious untill you read down thru the descriptions at first
