How likely is your car to pass an MOT
Going by the car makes it does seem quite stereotypical
The Germans are slightly above average
The Japanese are quite a bit above average
The french are rubbish
2006 Vauxhall Monaro VXR 6.0 V8
77.5% pass rate
6.5% fail on Steering (3 times worse that other 2006 cars)
6.1% fail on Tyres
4.8% fail on Lighting and signalling (59% better than other 2006 cars)
4.8% fail on Brakes
3.0% fail on Fuel and exhaust
2.6% fail on Suspension
2.6% fail on Driver's view of the road
2.2% fail on Registration plates and VIN (2 times worse that other 2006 cars)
0.43% fail on Body and structure
Volkswagen Polo, registered in 1993
49.0% pass rate
had mine 3 years and the first mot i just needed a bulb for the rear regplate
2nd it needed a new back box
3rd one this year it needed a midbox
for a 19 year old car i think thats very good
Ford Scorpio 50.5% - brakes and suspension most common failure (not suprising as they eat front wishbones and hand breaks sieze)
Lexus LS400 73%
No data for Westfields :(
The garage that I use generally have a quick once over and tell you if they know it will fail, then they work on those areas before doing the proper test.
77.5% pass rate
6.1% fail on Tyres
4.8% fail on Brakes
My 2004 CV8 just passed with zero advisories. 69.8% pass rate apparently.
1998 Nissan Primera 45% pass rate. Ive owned for 5 years and passed every time. It's a shame you can not filter to individual models.
It's also pretty obvious that the newer cars are going to have a lot higher pass rates.
