- 25 Apr 2011
- Crawley/Gatwick
mine is going back, rma requested
out of 3 cards gtx 670, gtx 680 and 7970 DC2 i would buy 7970. Costs a lot less, more ram, more bus and no dynamic oc which causes lag now and again. Nvidia need to sort themselves out
this won't do what you want it to... the card has a 300mhz transmitter but if your monitor doesn't have a 300mhz reciever it still won't do 120hz refresh / 3D
as far as I know, no consumer monitor / TV currently has a 300mhz HDMI receiver
max oc 7970 doesnt loose much ground to 680. Taking into account pricing 7970 actually wins. I think kfa2 uses lower grade components compared to asus, i wonder if anyone has gtx 680 top card and willing to post on here with some benches
what do you want doing? and it may take a while to do them
If you already found your max OC do you mind posting benches of unigine with settings in the unigine thread? 1920x1080 please
Could you do both stock clocks and max oc please?
http://forums.overclockers.co.uk/showthread.php?t=18386056
I've already posted in that with Sli setup ,both cards went to 1300 plus.
Page 27 for those results.
Didn't try with a single card but i'd imagine will be higher,will try to post later in the Unigine thread
Does the voltage control work and what is the Max voltage you can give these cards please?
your single card will demolish kfa2 even though yours has 8+6, cheaper and dual fan. KFA2 is a joke
