Also can I throw in the Fiesta ST aswell. Brilliant little cars.
Type of person is only 1 factor in the average MPG of a car.
Type of journey probably has a greater affect, but then there are so many factors to consider it's all really irrelevant, therefore the "average" across many users tends to shine a greater light on the true "average" of the car.
38mpg out of a Type R. You would have to drive motorway miles only, and probably maintain 60mph as well. Not where the Type R wants be to, so therefore an irrelevant purchase.
Far too underpowered, and every time you see a 197 you will cry a little inside that you didn't buy one of those.
Certainly not underpowered. Just not as powerful as the rest of the hot-hatch market.
How much did 'with ease' set the owners back? And 'strong engine' doesn't exactly equate to old school strong engines where you could bolt on a daft turbo to create crazy jap monsters with little extra work, I bet a load of work goes into getting 350bhp from the Fiesta ST.Also a brilliant strong engine that has seen a easy reliable 350bhp out of it with ease.
I will happily stand corrected.
A Ford is still a Ford at the end of the day, run of the mill and not exactly special.
300bhp on such a short wheelbase has a recipe for 'too much power' to handle
'Just gonna step on the POWER after I nip this corner * WHEN SUDDENLY TOURQE-STEER-UNDERSTEER-TOURQE-STEER-TREE *
Very true. I could see that being quite fun though, I should know![]()
[TW]Fox;22184839 said:Rule of thumb. If your budget doesn't punt you into the middle of the market for the car you want, then you don't want it. Never buy a car of which examples are onyl just in range.
[TW]Fox;22187325 said:Nothing in this thread is 'special', you don't buy this sort of car for 'special'. They are hot hatches - a Focus ST is, whilst unsuitable for a £5k budget no less 'special' than any other hot hatch.
Shouldn't a 'hot-hatch' be special, otherwise it's just a 'hatch'? The Mk1 and Mk2 Golf GTi were hot hatches and they were both pretty special (in their time). The pug 205 GTi was special too.
