Hi all. Not sure what the point of this thread is, just need to vent.
As probably all of you know, I bought a Leon FR TDI at the end of 2009. It was on 54K miles at the time. Since then, i've had about 40-45K miles of happy, trouble free motoring (bar a failed injector, covered by warranty) and whilst 45MPG isn't the best, it's far from the worst either.
The problems then started.
First I knew of it was when I got an engine error light on the M5 motorway one day, resulting in a loss of boost completely. Nothing would get rid, so I limped it back to the dealer who read the fault as "catastrophic underboost", but could not suggest any definite way to fix it. I had them check for the usual signs, but apparantly the turbo looks good and there are no leaks.
They reset the code and sent me on my way.
Now, since then, whenever the car has been on "DPF regen" - basically when it heats the DPF to clear away the build-up, I get very lumpy power delivery. The car "urges" under acceleration. It's a very odd feeling, but never seemed to throw any fault lights, so the dealer were utterly useless. I decided to just ignore it as the car seemed to be working.
So, 10K miles later and the main difference seemed to be that it was running a regen a lot more than usual, and having trouble clearing it. Often the filter light would come on and i'd have to go hoon it to clear the DPF up.
Until today.
Today I took the car a total of about 100 miles, and it was an absolute pig. Juddering, making odd noises, repeatedly going into limp-home mode, repeatedly trying to regen the DPF with little success. It feels down on power somewhat - not totally lacking in boost, but like the usual available oomph isn't all available.
I don't really know what to do - I don't want to have to drop what is looking like £1200 on a new DPF for a car that is worth probably less than four times that.
So yeah, i'm at my wits end. And here I am at 3.30am worrying that i'm going to have to sink that kind of money into a car that is barely worth it.
As for changing car, i'm SO CLOSE to being able to, it's just a race to see who can get there first - me with the money or the DPF failure. Because as I said, having to drop four figures on a new one would not be fun.
Thanks for reading.
Until today.
Thanks for reading.
