I put the build together on Friday, the only new component was the Asrock Z68 Extreme4 gen3 I bought from OcUK, the other stuff I bought on the MM, i5 2500K, RAM, Noctua cooler and graphics card.
I used my existing Akasa Eclipse case and Akasa 1200W PSU.
All went very well, overclocked using the boards BIOS auto overclocking, passed Prime95 for about 6 hours.
Windows7 install perfect etc.
I decided to plug in the Asrock usb3 port to the header and installed in the back.
I had of course turned off as normal and unplugged the power cord and waited for a few seconds before plugging it in to the board.
Turned on the pc and heard a little "phut" sound followed by a slight smell.
Now nothing works, at first the fans spun for a few seconds now nothing.
Is this a case for a board RMA?
